SOURCE: Toro Lawn Mower Won't Start
this is a very common problem with these toro mowers. the needle valve in the bowl of the carb. is plugged up with dirt or varnish from the fuel. just under the primer bulb there is the carb bowl. it has a nut under it that holds it on remove the bowl and make sure fuel flows constantly while the bowl is off. push up on the float to stop the gas flow. this could be messy and dangerous. careful with the gas. its flammable. best solution is to remove the carb and soak it overnight in a parts cleaner like gunk. caution small parts inside. this happins every year on mine no matter what i do. seems like the orifice is so small it clogs easily. good luck
SOURCE: my craftsman rotory lawn mower 6.5 hp self
You have water in in the carborator, I'll bet. I had this same problem. Here's what I did.
I emptied the gas tank, put in a new spark plug, changed the oil and then unscrewed thd big nut on the bottom of the float container (attached to the carborator near the rubber gas injector button) and emptied and cleand the float container. Then i put it all back together, pulled the cord and the same thing happened, but this time i could keep it going by having my daughter constantly pushing the rubber gas injector button. After it had run for a minute with this constant pushing of the button, all the water was gone from everytwhere and it worked.
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
SOURCE: my craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Don't need a new blade - just hardware to reinstall blade.
