Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Not Cole -- fan inside are blowing room temperature air
Side-Side Kitchen Aid with Ice maker and cold water. Not getting cold. Compressor feels warm, and the fan blade was touching the housing frame. The fan was not turning with the Fridge on.
  • 334 Answers
If after freeing the fan blade it still will not turn, you have a bad fan motor. (almost certainly due to it being restricted.)
That will cetrtainly cause it not to cool properly.
If the fan will not turn after freeing it, it will need to be replaced. If it does turn properly, unplug the fridge for about an hour to let the compressor cool down. Make sure all the coils vents etc are free of dust and dirt. Plug it back in, and if the fan is still operating properly, you should be back down to temp in a few hours max.
Posted on Aug 31, 2009
SOURCE:
Samsung why does my ice maker spit out water before the ice? Water dispenser also seems to have a slow leak.
First, I'm not a Samsung representative.
* Check your warranty. Call for support;
* Contact;https://www.samsung.com/us/support/home-appliances/refrigerators
*** The following is for information only.***
* The symptom of melted ice and water dripping from tray is usually caused by several things;
* Most common is ice build up in freezer coils. This happens every time the door is opened. Ice builds up on coils but is normally removed during a daily defrost cycle.
* The cycle may be unable to defrost all ice due to bad air circulation. Usually caused by rubbish blocking fan intake (bottom of freezer tray or wall.) Overloading food may cover the intake.
* Remove all food from freezer. Check for fan blockage. There should be a steady flow of cold air. If not then your freezer needs to be defrosted.
* Defrost by moving all frozen food to fridge side or cooler. Unplug fridge and open freezer door (drawer). Allow room air to circulate into the freezer. Use a house fan to blow air into freezer. (DO NOT use Hair dryer! It will damage panels.)
* Check and remove melted ice water. Check inner panels of freezer. Once defrosted the panels will be room temperature to the touch. There should not be any condensation or coldness to the panel. If it's still cold then keep defrosting.
* Once the water stops dripping. then close freezer doors.
* plug in freezer and wait 5 mins. Check freezer if inside is cold and the air is blowing cold. Reload freezer with food, take care not to overload or cover fan intake. Monitor for 2 days.
* Cleaning (Official); https://www.youtube.com/watch?v=AooBAPlk-Ts
* French door drawer; https://www.youtube.com/watch?v=_ZYLIRN_pk0
* Removing trays; https://www.youtube.com/watch?v=VxTliAhbr14
* Cleaning the back with a vacuum cleaner; https://www.hunker.com/13419629/how-to-clean-samsung-refrigerator-coils
* Freezer not blowing air or not cold? Bad fan, thermostat, pump. Call for service.
Aloha, ukeboy57
Aug 09, 2018 | Samsung Refrigerators
Freezer not getting cold and dripping water
I own a similar Kitchen Aid fridge that had a defrost icing issue: Kitchen Aid KSRP25FNBL00
> Ice had plugged the drain hole at bottom of chill coil section inside the freezer compartment.
> I learned that the coil, circulation fan was not working, but condenser was working.
> I paid a tech to replace the circ fan, about $200, including a new swiss-made fan. He said it was unusual for these fans to fail, but not unheard of.
Expensive, but saved the purchase of a new fridge. Has worked great for 6 months since then.
HOpe that helps.
Al Zayha
Mar 09, 2014 | KitchenAid (KSRD22FKST) Side by Side...
Kenmore 253. 9287413 Can't get the freezer to get cold enough. Freezer alarm keeps turning on and the temperature is only 25 degrees inside. Temperature alarm light stays on all the time. Quick freeze...
You can fix this, just follow the procedure given to enable get back your refrigerator going,
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
I hope this will help in solving the problem......
May 10, 2011 | Refrigerators
MY FREEZE WILL NOT GET COLD OR FREEZE ANYTHING
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
If you have an ice-maker, check freezer and ice-maker for level.
With all this it helps to solve the problem....
May 04, 2011 | Kenmore 14.1 cu. ft. / 399 liter Upright...
KITCHEN AID REFRIGERATOR PROBLEM We bought a used Kitchen Aid fridge YKSRS22Q (1993), the ice maker is not working but water does work. What should we check to see why the ice maker doesn't work?
Ice makers work off of temperature. If it's not cold enough in the freezer it won't work. Check the temperature with a thermometer, it should be 0 to +10F
Jan 29, 2011 | Refrigerators
Freezer not cold.
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
Hope this will help in solving the problem.....
Oct 07, 2010 | Frigidaire Refrigerators
Dehumdifier not collecting water.
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
The freezer side is not keeping food frozen. Every three minutes I hear something turn on and it runs for about xx seconds. The model number is ASD2626HES. The refrigerator side seems fine.
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
Hope this solved the problem, Take care....
Sep 19, 2010 | Amana ASD2626HE Stainless Steel Side by...
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Sep 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
75 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
Jimmy
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
