Question about Car Audio & Video
My car stereo sometimes play and sometimes not. I think it is because of virus. Please help.
My car stereo only works in aux
Sounds like you have a dodgy connection in stereo's wiring if it works sometimes. Hope this helps.
Mar 21, 2014 | 2001 Dodge Durango
I try to install a second amplyfier to my car stereo, the problem was that both the output wires for the speakers... the positive and the negative wires made contact. Making a short at the stereo. Now, the...
i know it sounds like its too easy to be true, but try checknig all the fuses. sometimes cd players have fuses inside them also. i dont reccomend taking it apart, but if your desperate try it
Oct 20, 2009 | Alpine CDA-9851 CD Player
My usb car stereo dosnt play all the songs on my kingston
Not every car stereo can play every song in a usb.
This deppends on how many songs and how many folders you have in your USB, regardless of the USB's capacity. My car stereo for example, can only play about 50 songs pero folder and i think it tops at 9 folders.
Try to organize your music in folders and change the names of the songs taking every "·$&%/&$/)(=)(( Symbol and non regular character out.
Or better, get your car's manual and it might say how many songs it can play. i think mine cant read over 1.5gb. if it doesnt say, you just have to try and work with it till you get it figured out.
The last thing i try and it might work:
Cut everything out of your USB, format it and then paste everything back this refreshes the USB and sometimes it works.
Sorry about my english.
Sep 25, 2009 | iLO XM-MP3-CD Car Stereo
"err" with CD player
it sounds that your lens could be damage or your loading mechanism, 1st try using a cleaner to clean the lens if that does not work , your either need to get the factory stereo service or start thinking of a new radio
Jul 13, 2009 | Corvette Chevy Malibu 90-04 Car Radio...
'99 ford escort radio changes modes then turns off
Its my belief that stereos in vehicles can become corrupted by maleware code. Do you play mp3, ipod, or burned cds in the stereo. I broke my factory stereo when I played a burned cd once. The market is ripe for virus and maleware protection for your car stereo so don't be surprised if you see virus protection and their virus creating friends on the scene soon. "Try reseting the stereo". You can also try to pull the ground to the car battery for 2 minutes but you will have to let the car idle for 10 minutes after you reconnect the post to set the idle correctly and let the car essentially reboot. Also jump starting a vehicle could cause malfunctions in the stereo if not breaking the electronics inside, very likely in the colder climates.
Jan 27, 2009 | 1999 Ford Escort
JVC Car stereo with cd shuts off when volume is turned up
Hi Ithink , you are trying to push too much power to your speaker setup. Your cd, tuner, player, is only go as loud as the volume at half way setting. Your speakers are , probally good ones that want more power, and making your player overheat and making circut protection cut power. I would say, you should use it at 15, and that is as loud as it should be played to aviod distortion and overheating.
I'm guessing max is like 25 or 30, Is that so? You can listen to louder tunes by installing an amplifier. Or if you have an amp in your system it may be overheating, I would really like you to let me know if you have been trying use it at volume higher than half the maxium volume setting, so I know I helped, and you can start looking into power amp's. You can crank it up for good parts, but most players were not made to send alot of juice to good big speakers at high volume level.
Tell me what you think, tooldoc
Dec 05, 2008 | JVC AM FM CD DET FACE CAR STEREO
Need antivirurs of k810
? u need antivirus for your phone you cant get antivirus for your phone
Jul 17, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Kenwood KDC-119 car stereo problem
There is a small hole at the bottom of the stereo face that will reset the system. I pushed a pen tip into the hole and it turned the stereo off. When I removed the pen, the system turned on and the CD ejected. Problem solved.
Jul 02, 2008 | Kenwood KDC-135 CD Player
Alpine cdm-7833 cd car stereo code
I didnt think alpines had codes?
are you sure it has one?
sounds more like a connection problem
Feb 09, 2008 | Alpine CDM-7833
Fitting a pioneer stereo
you need a ford to pioneer wiring adapter. available at any stereo shop.
Aug 30, 2007 | Pioneer DVH-P5000MP - Car Audio DVD/CD/MP3...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
