Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Hello, i have a sony FD Trinitron WEGA #KV-36FV310 ... Need to know whichoptocoupler ic is used in str 6267 based power supply in sony trintron crt tv.
www.fixya.com > Forum > Standard (CRT) Televisions > Sony
Need to know which optocoupler ic is used in str 6267 based power supply in ... My sony crt Tv totally dead when touch any components and the IC strs6307 ...
If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
If that is a chip in the power supply unsolder all pins and get a pin out of it to test it for a short--if shorted and no short to ground at HOT replace it.
Hi I would hazard a guess at STRS6707 as these are the most popular switching regualtors, not knowing the tv make & model number makes it difficult to be abolutely sure.
Before replacing the STR, have you checked all the components related to it? When STR burns out some of the nearby components, such as zener diodes and other resistors will also get damaged. You just replace the components, especially, zener diodes, in case it does not show any fault, replace it. Connect a 100W filament type bulb in seris with the power supply, and switch on the set. This will reduce the power concumton at the begining, and we can check its heat effect also, after all are ok we can connect directly. Check the smoothing capacitor at the secondary 130VDC. Replace it also. If you need furthermore assistance, feel free to contact me through Fixya. I'm an Indian, residing at Trivandrum, the capital city of Kerala State.
In the past, my experience with Sonys is that you need to use Sony parts to successfully repair them. Also you might have a cold solder joint which creates an arc when you turn it on.
This arc will cause a "spike" which could possibly take out the regulator.
Stargazer
