HD drive should be suspected. seek tech support. Do no do anything by yourself at its circuit board. Seek tech support. The work is a very skilled one.
1. Press MENU to display the MENU screen, and then press c/d to select "Digital Setup". 2. Press a/b to select "Audio Setup", and then press ENTER. 3. Press a/b to select "PCM" or "Dolby Digital", and then press ENTER. 4. Press MENU to exit.
PCM The optical output terminal output studio signal in PCM form. If your digital audio system does not support Dolby Digital, select "PCM".
Dolby Digital The optical output terminal outputs audio signal in Dolby Digital form. it reproduces sound from surround program of digital.
also check the input assignment of ur dvd palyer's tv input. if it is selected as analog then change it to digital. ok
You may need a new fan, but you can try cleaning the fan. Remove fan from player. use a few drops of WD-40 or another similarlubricant, the fans label may need to be removed. Note Panasonic fans must be rotating or f61 code will appear. Hope this helps.
Had the same problem. Found that the code refers to the cooling fan. Could be that the fan is dusty or not running when the system starts up. I removed the fan with the two screws and reseated the plug. Make certain that the short, black wire (that seems to go to nothing) is securing the plug to the board.
heat sink and ic is heating on play the song
heatsink and ic's heated
