SOURCE: Keypad not working during phone call
If sounds like DTMF is turned off on your phone. If it is then it is not sending the correct tone over the air which is why nothing happens. Go into setting, then to initial setup and key down toward the bottom and you should see DTMF if it is off change it to short or long and that should correct you problem.
SOURCE: phone call cutting out during a call
your battery is old and need to be replaced with a new one (buy a original one if u dont want more problems)
SOURCE: using home phone causes comcast wireless internet to disconnect
Wireless internet runs at 2.4ghz. Your portable phone is probably also 2.4ghz and is knocking out your internet connection when in use. Look for an 800mhz or 5.8ghz phone as a replacement.
SOURCE: I bought yesterday my Samsung
Open the menu bar, cliq on settings, then cliq on call settings then check if it is on any key answer, then choose the key you want use in answering your calls.Thank you for using Fixya.
