Dishwasher initially stopped with an E1 code. Pipes all checked out OK.
When switching on now, it makes a loud noise and the motor sounds like it is straining.
The drain hose is higher than the machine, so there is no problem there.
E1 leakage error
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Replace the connections of Hose. Check the point of damages and repair or replace the related parts.
Replace the Impeller of the Washing Pump.
