The blade starts to engage but the motor dies.
SOURCE: Husquavarna GT2254 runs fine till I try to engage the blades,
Hello janec37415:
>>From your Description it Sounds like the Seat Safety Switch is Bad, has a Bad Connection or the Stator/Charging Coils are Not Charging Enough for the PTO to be Engaged.
>>When the Blade is Engaged, the Seat Switch is Showing No One is on the Seat so the Engine is Shut Off by the Safety System or
>>When the PTO is Engaged and the Stator/Charging Coils are Not Charging Correctly, the Carburetor Solenoid Does Not get enough Voltage to Stay Open and the Engine Quits.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
SOURCE: pto not engaging blades
Lets start from the beginning:
Do you have power going to the switch you need to check this with a volt meter it should read between 12 and 13 volts with thew engine off
if you have power to the switch next we need to check to see if there is power coming out of the switch again check with a volt meter.
if you have power coming out of the switch then we need to see f power is getting to the relay on the battery terminal and the switch terminal and if there is power to both terminals then we need to see if the relay is functioning correctly ( check output terminal with voltmeter)
If we have power to and through the relay we need to see if we are getting power to the clutch ( check this at the clutch) if there is no power to the clutch trace your wires back until you find power and make the repair. If ther is power to the clutch but the clutch does not engage you may have an open ground meaning the circuit is not complete again check your wiring. If everything checks out but the clutch does not engage then you have a bad / open in your clutch hope this helps
SOURCE: Riding mower stalls when PTO is engaged.
check the kill switch and the wire it could be that a small piece of the covering came off and is grounding to the deck or frame there by killing the engine the jerkink of the mower maybe whats causing the wire to come into contact with metal..good luck
SOURCE: PTO problem on a model
I would be looking at the ignition switch....but before replacing it I would be looking for a friend with an electrical meter and checking the wiring for power coming out of the switch to the cluthch, this way you can narrow it down positively before buying parts.
heatman101
