n
nicodemus amboye Posted on Jul 16, 2019
Hp laserjet m3035 mfp ouch screenn frozen. tried switching on and off but no change. screen still unresponsive
  • Patrik Parker Jul 17, 2019
    Hi nicodemus amboye, I want to help you with your question, but I need more information from you. Please call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7
1 Related Answer
Ahmed aljabry
  • 10 Answers
  • Posted on Sep 10, 2018
SOURCE: from computer How can i scan document from HP LaserJet M3035 MFP
Hi, you must first install the scaner driver in order to scan from computer, then follow the steps from it
From computer How can i scan document from HP LaserJet M3035 MFP
An email address must be provided for email notifications
I accessed the printer thru the web interface>Log In>>Digital Sending>Send to Folder Settings and under the Notifications I changed it to Print . It was set to Email Sender. We don't email from scanners not sure where that setting is located.
HP LaserJet M3035 MFP Series
Method used to deliver notification: Print
2helpful
How to scan to computer using hp laserjet m3035xs mfp connect using a USB CABLE
install the scanner software on your cd hp and then in Word go "insert+image+scanner"
Bran new HP m3035 MFP.
Try replacing the toner if you have another one, even old one should be ok to test, if not the look at the toner drum and see if there is any marks on it.
2helpful
How do i scan on HP LaserJet M3035 MFP from computer?
Assuming your scanner is installed already, what you need to do is log into Windows Photo Gallery (Vista) and click on FILE at the top left. When the drop down bar engages, you should look for IMPORT FROM CAMERA OR SCANNER and click it. Then a new window will open up and you'll have to pick your device (HP Laserjet M3035). At this point check your settings, and make sure your scan is ready, then click on either PREVIEW or SCAN. Then when it is done scanning, you will have to go to the folder you saved it in to view it. (Xp Similar)
Hope this helps.
k24674
Grand Canyon Tech
Grand Canyon Tech
