Looks like it may be too old? Lots of help below, but this seems hopeful.
https://community.roku.com/t5/Roku-setup/Roku-Ultra-with-an-older-HD-plasma-TV-with-1080i-resolution/td-p/561009
Does a Roku Stick Work on Any TV?
The Roku Streaming Stick
4K is designed to be compatible with any TV that has an HDMI port. This means it will work on both smart and non-smart TVs, as long as they have an HDMI connection.
If your TV is analog, don't worry! You can still use the Roku Streaming Stick 4K by using an AV Composite Converter. This will allow you to enjoy all the features of the Roku Streaming Stick on your TV.
All Roku streaming players will work for any television with an HDMI connection, so any Roku player can be connected to a 4K UHD or HDR-compatible television. However, to stream movies and TV shows in 4K UHD or HDR you will need a compatible Roku streaming player and television that supports 4K UHD or HDR.
Jul 24, 2023
Do I need a special TV? - Roku Support
Roku
https://support.roku.com > en-ca > article
Does Roku Work on Any TV? Here's What You Need to Know
The Home Theater DIY
https://thehometheaterdiy.com > does-roku-work-on-a...
2 days ago - Yes, Roku does work on basically any TV as long as it has an HDMI port. Older, lower resolution TV's probably don't need the most updated 4k ...
How to set up your Roku streaming player or ...
Roku
https://support.roku.com > Roku setup
Jul 24, 2023 - From a USB port on your TV Any Roku Streaming Stick supports USB power, but only some Roku players do. If you are connecting your Roku device ...
Roku TV · ‎
Roku Streaming Stick 4K · ‎
4K TV · ‎
Roku Streaming Stick 4K+
Compatibility Unleashed: Does Roku Work on Any TV?
Automate Your Life
https://automatelife.net > does-roku-work-on-any-tv
1 day ago - The Roku Streaming Stick 4K is designed to be compatible with any TV that has an HDMI port. This means it will work on both smart and non-smart ...
Does a Roku Stick Work on... · ‎
Steps to Install Roku on an Old...
