I lost my instruction sheet and cannot remember how to set chimes. It chimes at 34 minutes past the hour.I lost my instruction sheet and cannot remember how to set chimes. It chimes at 34 minutes past the hour.
You can't post conmments that contain an email address.
Press the mode button until the Alarm apears. Press the Start/Stop button to turn the alarm on/off and remove/add the chime. Whew! I had to figure this out after my 3 year old turned the chime on!
Try this:
To set time and date:
1) With time and date showing, press SET.
2) Seconds ?ash. Press START/STOP to round time to nearest minute,
setting seconds to zero.
3) Press MODE. Hour ?ashes. Press START/STOP to change hour,
including AM (no symbol) and PM.
4) Press MODE. Minutes ?ash. Press START/STOP to change minutes;
hold button to scan values.
5) Press MODE. Month ?ashes. Press START/STOP to change month.
6) Press MODE. Date ?ashes. Press START/STOP to change date.
7) Press MODE. Day ?ashes. Press START/STOP to change day.
8) Press MODE. Time format ?ashes. Press START/STOP to select
12- or 24-hour time format. 12-hour format has AM/PM.
9) Press SET, at any step, to exit and save settings.
Date (day of month) appears in upper part of display in Time mode.
Press and hold START/STOP to see month and date in large digits.
Go to the time mode,hold down the set button, it may take a couple of seconds and it will start blinking , then go to your mode button to move from seconds to hour to min etc.etc,etc. It probibly is your start/stop button for chaning the numbers. If that dosn't work, hold down the mode button on the time mode for a few seconds, and go from there.
Solution #2 by Guest, posted on May 13, 2008 solved my problem. OUTSTANDING solution #2!
1. Hold in the MODE button until the alarm time appears. 2. VERY IMPORTANT - release and TAP the MODE button AGAIN, and the time should appear with the seconds flashing. 3. Use StART/Stop to choose among seconds, hours, and minutes, and 4. Use ADJUST to increase the selected number 5. Press MODE to put the thing back in regular operational mode.
After several attempts with other directions over the last four months, these 5 steps WORKED.
For Timex sport 1440 indiglo page through mode (bottom button ) til u get to time When time shows up hold down lap/rst button on right untilset starts flashing use mode buton at bottom to find element you want to change (let's stay minutes) put st./stop button at top to get to number (minute) you want hit lap/rst to get out.
If your set up is: Top-Left=Indiglo Top-Right=St./Stop Bottom-Left=Mode Bottom-Right=Lap/Reset
Than follow these steps: 1. Press Lap/Reset and hold. You should see the time the alarm was set for. 2. While holding Lap/Reset, press Mode. 3. Let go of all buttons. 4. There you go!
In "Time Mode" when time is displayed, hold the "mode" button until the alarm flashes. Press the "mode" button again and the display should change to the seconds flashing. Press the st/stop button to change location between seconds, minutes, hours, date, month, and day. Use the lap/reset button to make any changes.
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US) These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
Press ADJUST to set SECONDS to zero.
Press START/STOP to select MINUTES.
Press ADJUST to change.
Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
Press MODE when done.
To display DATE from Time display , press START/STOP.
With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
Press ADJUST to change.. Press MODE when done.
Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
With time displayed, press MODE to select Chrono Mode.
Press START/STOP to start.
Press ADJUST to view lap time. Press again to sesume lap timing.
Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
