I have a moen kitchen faucet with a pull out spray spout that leaks at the base of the receptor only after turning the water off. It's not a steady stream, it just seeps. I don't know the exact model #. What needs to be replaced?
You have a bad internal o-ring or the sprayer o-ring is leaking, if you look under the sink turn it off and then turn it back on, if you see it leaking out the center shft where the water pipes go into then the faucet may have a broken pipe or loose pipe. check and tell me where it's leaking at. You can buy kits to repiar them they are inexpensive.
It's not leaking underneath the sink, only on top from the base of the receptor.
the spout is leaking water from the underside cover.
