Question about Sony Televison & Video
Sony KDF-55E2000 heard a pop the picture and sound went off red light was blinking steady I turned power off by switch on tv again to turn back on nothing happens but red light is blinking 3 times
SOURCE:
  • 51 Answers
SOURCE: Sony Grand WEGA KDF-55E2000
in this set 3 blinks means lamp cover not set properly but i think that your problem is your 6x red blinks that means you have a problem in the audio section in your set(missing a voltage) or a themal fuse open.
Posted on Jul 10, 2008
  • 320 Answers
SOURCE: sony KDF-42WE655
Bad lamp and/or lamp driver. Try replacing the lamp first.
Posted on Oct 18, 2008
jerryg50
  • 1691 Answers
SOURCE: Viera TH-65PZ850U
Without investigation it is impossible to know what failed. There are a number of boards in that set where there is fairly high current used. It is possible that some components have failed.
The Panasonic service rep would service the set by swapping out the failed modules. If the set is an older model the modules may no longer be available. You can take the set in for an estimate to see if the parts are available, and to see if the set is worth to service.
Jerry G.
Posted on Jan 17, 2009
  • 90 Answers
SOURCE: KDF-55E2000 getting 3 red lights
replace the lamp.
Posted on Jan 03, 2011
SD Tech
  • 14553 Answers
SOURCE: Sony kdf-55e2000 red light blinks 3 times- tv will not go on
3 blinks is a error code "lamp door not properly closed" but what it really means is the lamp door is warped from heat from the lamp.
The door if removed has a plastic peg on its back side-the peg when door is in place engages a tiny lever behind it----
What to do?
Remove door and engage the lever with something not metal==turn set on and if it comes on you know the door is the issue.
DO NOT LOOK DIRECTLY AT THE LAMP- DO NOT OPERATE SET PROLONGED TIME WITH DOOR REMOVED OR COVERED WITH ANYTHING ELSE==THIS IS ONLY TO SEE IF THE DOOR AND SWITCH ARE YOUR PROBLEM.
SD TECH
Posted on May 23, 2012
I've got a Sony Wega KDF-55E2000 there was an
replace teh lamp its might have exploded if its okey check the power supply board but most likely the lamp needs replacement
Jul 16, 2013 | Televison & Video
Heard a pop when I turned on tv and now nothing
don't leave it on and have it looked at---most likely is if it uses a lamp that may be the problem but if not it may be in the power supply.
May 20, 2012 | Sony KDF-E55A20 55 in. LCD Television
I have a 60" Sony
It seems lamp/ bulb popped again, check lamp inside tv.
If tv does not show red blinking light then it would be lamp that knocked off, replace lamp in tv to fix its problem, please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
Jan 15, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
No Video/Sound,POwr Gren LiTE Blinks 4Ever, SONY WEGA KDF-55WF655
Please check lamp in tv as pop sound seems broken lamp.
Did you replaced lamp in last 2-3 years in tv? If not, then its lamp that got broken and tv needs new lamp.
Lamp replacement procedure is written in user manual and its easy, please buy Sony original lamp for good picture in tv.
Thanks.
Apr 25, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KDF-42WE655
Aug 20, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
No picture; No sound
how many times does it blink red? It should blink so many times then stop then blink again. how manty times does it cycle?
Jan 02, 2008 | Sony KDF-E42A10 42 in. LCD Television
2000 27" Sony Wega
Sony has a code for those blinks indicating the problem area. Count the blonks till the pause then google Sony blink codes for the area to fix.
Jul 03, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Televison & Video Logo
22 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
