Error message received on jvc hard disk camcorder (GZ-MG77U) when properly connected to jvc dvd burner (CU-VD10) that reads: "incompatible disc! change disc". this same message appears on all new dvd-rw discs used with the device.
Sounds like there last on one of the units has worn out I'm afraid. Can you not try on a different burner as if that works then at least you'll know which unit is faulty.
Your burner has gone south. You can try a firmware upgrade to possible correct the issue but if that does not do the trick then the burner needs to be replaced.
I BUT A JVC EVERIO BURNER AND I CANT BURN MY VIDEOS FILES I insert the Disc in the Burner, it tries to recognize the disc and then comes up with , DISC ERROR CHANGE DISK
