Check and see if you have a bent blade. If bent replace. If the blades are not bent then you need to check the levelness of the deck. You can measure the distance from the blade to the ground on all the blades. Make sure you are on level ground. If one set of blades is higher or lower you will need to level the deck. Refer to you owners manual. If no owners manual there is probably some hangers that are threaded and has a nut on it. Loosen one to lower and tighten to raise. Only do one side.
good luck
roundo4
