SOURCE: wiring diagram for ford 9n tractor
You can purchase a manuel for your tractor at Tractor Supply or at tractorsupply.com for about $25-$30.
SOURCE: install distributor points on ford 9n process needed
try this site... http://www.ytmag.com/atrp/specs/ford.htm
SOURCE: I have a 2n ford tractor. Starts great but will
Hello
Have you Checked the Point Set Gap?
If the Point Set Gap is Not Set Correctly or the Contacts are Burnt, then you will have this Problem.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: Ford 2n tractor. Engine turns, but very slowly. Is
you can get a replacement for that starter at most auto parts stores. there is nothing on the N series tractors you can't buy on line, even complete engine rebuild kits and fenders. look for antique tractor parts suppliers. is it a 6 volt or converted to 12 volt?
