Question about Acer Aspire 5610-4648 Notebook
SD Card Reader Not Working on Acer Aspire 5600 Laptop
Found my SD Card reader would not auto recognize whn inserting a card. Loked in windows explorer under my computer and the reader was not showing up. Went in to device manager, uninstalled the driver and reinstalled it with no luck. Still will not show up under my computer
  • 29 more comments
  • Anonymous Dec 09, 2007
    my Aspire 5570z card reader does not work. I can't even find it
  • Anonymous Dec 10, 2007
    i have the exact same problem
  • chipdawolf Dec 27, 2007
    i have a aspire 5360 and when ever i put my sd card in the computer dosnt locate it.
  • Anonymous Jan 02, 2008
    Acer Aspire 4520, same problem as Scarecrow. Checked out the link to Microsoft's Hotfix that was provided by Country. Looks like a viable solution, but the only problem is my driver version ends in 25088; the Hotfix is for the version ending in 20634. Guess I'll keep checking back here for an update.
  • silva_den Feb 02, 2008
    Have an Acer 5110. My daughter put a memory card in the 5-in-1 card reader. How do you remove it?
  • Anonymous Feb 18, 2008
    I have a 5102 WLMi, and when I put the card in it just pops up with the safely remove hardware icon. I also have an SD/HC 4gig card and it does nothing when I put it in. Any suggestions? Thanks
  • Anonymous Feb 19, 2008
    Inserted 4Gig SDGC card in the Acer Aspire 5610 and .... nothing! First try no steps taken. Will try to look other places on the web for hints or call Mfg... Bill
    In my acer aspire 5610 laptop card reader does not works from the beginning...
    now acer logo does not displays on booting...
    now it was infected by 8h3hh3m.exe virus, please sent me solutions to remove that virus...
  • mokjok May 06, 2008
    I'm using Aspire 5610AWLMi. The card reader also doesn't work, and very difficult to find proper driver download source, even at Acer's site. Still can't find any solution.
  • Anonymous May 17, 2008
    Tengo una ACER Aspire 4520 con el mismo problema. No logro hacer que lea tarjeta, si la lee, pero dice que esta bloqueada que si se quiere formatear y cuando lo hace, da un error y dice que no puede ser formateada.
  • dumpycactus May 28, 2008
    same problem, SD card is not being recognised on my Aspire 5580.
    it had worked before when I was running on Vista, but now I've switched to XP Professional 2002 SP2.
    i'll check the drivers again...
  • Anonymous Jun 03, 2008
    I accidentally uninstalled the driver and the software got deleted. Where can I find it to download it again?
  • Anonymous Jun 07, 2008
    i need help!!!!i have a prolblem with y acer...i reinstal my windows same days ago and my card reader doesnt work what to do?i need some drivrs? thank u verry much
  • Anonymous Jun 15, 2008
    microsd sandisk in acer aspire 4520 not working. when trying to open the card drive it instructs to format and when trying to format it says not usable and cannot format. But the same card works well in dell computer. why is this happening?
  • eiramesor Jun 23, 2008
    can you please send me the drivers for my laptop Acer Aspire 5610-4648 PC Notebook because i am now using Windows XP 64 bit
    thank you...
  • Anonymous Sep 10, 2008
    my comp wont read my SD card ... i have an acer .. aspire 5570z
  • Anonymous Nov 24, 2008
    I have Acer 3025 wlmi. The laptop will recognise a 1gb micro SD I have in an adaptor but will not recognise a 2gb Sandisk Ultra or 4gb (not SDHC) Transcend SD cadr I have. Just doesn't appear in explorer as if the card has not been inserted.
  • Anonymous Nov 26, 2008
    same problem.
  • Anonymous Nov 29, 2008
    i have the same problem. my sd card reader all of a sudden stopped working. i've reinstalled drivers but when i put a card in it just doesnt recognize it.
  • Anonymous Dec 17, 2008
    Acer Aspire T650 pc - doesn't recognised SD card
  • Anonymous Jan 06, 2009
    i ahve the same problem
  • Anonymous Jan 07, 2009
    same
  • Anonymous Jan 30, 2009
    where does the SD card go?
  • mochaguy22 Jan 30, 2009
    yeah i have the same problem and i think it's bcos any sd card higher than 2gb doesnt work. need to fine a fimeware or something.... anyone know a link for download?
  • Anonymous Feb 15, 2009
    acer 3600 desktop does not read any sd card when inserted.
  • sparky3542 Mar 01, 2009
    i have the same problem on an acer aspire 5735z. what needs to be done for card to be seen when plugged in?
  • Anonymous Mar 01, 2009
    Got the same problem with acer aspire 3680 running windows vista home basic
  • Anonymous Mar 02, 2009
    I Have Acer 5920,wont recognise SD card from Canon and Kodak cameras. It will recognise the half size camera card from Olympus.I cant get any success from any Acer website, all seem to be having the same problems.Where do I go, and what do I do???I need this SD Card reader to work for my job....
  • johnjeevaraj Mar 17, 2009
    I have ace Aspire 5570z note book, my card reader is not working
  • Anonymous May 14, 2009
    sam her -,- (Acer Aspire 8930G)
  • khanpaseuth
    khanpaseuth May 29, 2018
    what is the 'serial number
I changed my hard drive .. and my computer has an SD slot .. but it wont read my card when i insert it .. odes it have to do with the new hard drive .. what can i do ..
Posted on Sep 10, 2008
  • Dan Klepsch Oct 15, 2014
    The slot wouldn't read an SD card on my laptop either. I had to use a card reader, in this case a camera, to read the SD card...
I had a similar problem where my memory card reader would not show up in explorer. I found the problem was linked to using a USB mouse. There seemed to be some sort of conflict. I did a bit more looking around and found a solution that worked for me here....
http://www.runpcrun.com/cant-install-usb
I basically browsed to c:\windows\inf (which is a hidden folder so you must unhide it in your folder options) right clicked usb.inf and selected install. Everything started working.
Posted on Jun 11, 2008
  • vlpoirier
    vlpoirier Aug 27, 2012
    My machine would not allow me to do so......
Cant see my sd card when i put it in,
dont think the drivers are installed.
can you help ?
i have acer 5600 running vista home premium
thanks
Posted on Oct 22, 2008
Try rebooting with a card in the card reader. Worked for me running Vista on an Acer 5735Z.
Posted on May 19, 2009
    Problem Solver:
  • 13 Answers
I had the same problem on my Acer Aspire 5630.
First I tried installing the drivers I downloaded from Acer's website for my computer (which in my case were called CardReader_ENE_3.00.00_Vistax86). I even restarted the computer as it told me to. But that didn't work.
Then I removed the drivers completely (and said Yes to Windows Vista's question about whether it should delete the drivers from disk).
Then I installed the drivers downloaded from Acer.
And now, even without having restarted the computer, it works! I can change SD cards, and Vista immediately responds to it.
Posted on Aug 13, 2009
Hello all. Good news. I installed Windows 7 on my Acer 5601, which originally came with XP, and the card reader stopped working. But I went to the Acer website and downloaded the XP driver... works like a charm! Pleasant surprise, since Acer doesn't seem to support upgraded operating systems. Hope this helps.
Posted on Feb 15, 2010
  • 3 Answers
I have an Acer 4520 and my internal memory card reader would not read a regular SD 2 GB card and kept telling me it needed to be formatted, I did this numerous times, with the result being unable to format. The reader had no problems reading and writing to a 4GB Mini SD with adapter. I thought this was strange, so after doing a little research, I ended up going to Acer's site, where I found a driver for the reader, and installed it on my computer. I then went to Microsoft's site and found the Service Pack 1 for Vista and also installed it on my computer. After doing both of these things, the reader formatted without any problems. I then made the mistake of thinking the Service Pack did the trick, so I removed the driver from Acer, luckily for me, Vista recognized what I did and went online and found the software to make the reader work again. So I am assuming that for this particular Acer, getting the driver from Acer, and if you don't already have it, getting the Service Pack 1 for Vista, might help fix problems that are occurring with the internal memory card readers on the computer. Hope this helps someone.
Posted on Apr 10, 2009
    New Friend:
Think it is a power issue, to many usb's eat all available power and the first item to get drained of power is the sd slot. my aspire 5600(5633) had the same problem all i did was unplug my external hard drive from usb and the sd card was recognized instantly. i would suggest removing usb items one at a time and see if this resolves the problem before messing about with drivers.
hope this helps you Scarecrow2 or anyone else.
Bert.
Posted on May 26, 2010
  • 54 Answers
Don't know why but Acer tend to have driver that may and may not work, then wants a fee for support. Check the driver version for SD controller in device manager. Then google to search for newer driver. Lot of times, I managed to find a driver that is updated to fix the bug for Vista.
If you have XP, search on Microsoft, they have a patch that will fix the SD card reader problems.
Posted on Nov 19, 2009
  • 383 Answers
Some Secure Digital (SD) cards may not be recognized in Windows Vista View products that this article applies to. function loadTOCNode(){} Article ID : 939772 Last Review : August 29, 2007 Revision : 2.0 On This Page SD Card Reader Not Working on Acer Aspire 5600 Lap - downarrow.gifSYMPTOMS downarrow.gifCAUSE downarrow.gifRESOLUTION downarrow.gifHotfix information downarrow.gifPrerequisiSD Card Reader Not Working on Acer Aspire 5600 Lap - downarrow.gif> downarrow.SD Card Reader Not Working on Acer Aspire 5600 Lap - downarrow.gif_miRestart requirement downarrow.gifHotfix replacement information downarrow.gifFile informSD Card Reader Not Working on Acer Aspire 5600 Lap - downarrow.gif/a> Windows Vista, x86-based versions downarrow.gifWindows Vista, 64-bit versions downarrow.gifSTATUS downarrow.gifMORE INFORMATION To resolve this problem, submit a request to Microsoft Online Customer Services to obtain the hotfix. To submit an online request to obtain the hotfix, visit the following Microsoft Web site: http://go.microsoft.com/?linkid=6294451
Posted on Dec 06, 2007
    New Friend:
If your Acer Aspire will not read SDHC or you can't get it working with Windows 7 or 8, use this TI card reader driver install by Toshiba. Uninstall your existing driver, then downloa and instal this one. It works perfectly on my 9410z. This driver works for all the Acer TI card readers. http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/downloadDetail.jsp?soid=1713025&pf=true
Posted on Dec 28, 2012
  • vlpoirier
    vlpoirier Dec 30, 2012
    I just used this hack on my Acer 5570z. Worked. Thanx!
  • Acer Master
  • 2,010 Answers
Try ithis kind of p[roblems if there was knowledge by the specifications of the hardware noithing wrong , try it with a bootable LINUX live cd / dvd .
Knowing that there will in the time new firmware or later software that will waiting a little time solving problems by the brand on new hardware the revisions on the series sometimes requires a little patience
Posted on Apr 19, 2018
Are the contacts on the card ok? Have you tried another card? Have you gone to START....COMPUTER...RIGHT CLICK MANAGER? is the device not being recognised on there? Is there debris inside the reader? Can you find away of clearing out anything which may be INSIDE the card reader?? Its always a possibility when you think of how many people take food and drink and sit at the computer and drop food over the keyboard and everywhere else. I've dropped a WHOLE cup of tea over my laptop...incase anyone reading this does the same......quick thinking...tip laptop upside down...immediately remove battery.
remove as much of the water or tea or moisture as possible WITHOUT turning the laptop right way up. find somewhere warm and dry and store the laptop for at least 3 days fully open.. I did exactly this and after three days decided I had given it enough time. I plugged the battery in and it worked fine. I guess I was lucky and quick thinking saved a £400 laptop. I hope this helps anyone reading.
Posted on Nov 18, 2015
    New Friend:
I have ace Aspire 4736g note book, my card reader is not working
Posted on Jul 18, 2010
WAH MY SD card suddenly stop working and the computer cannot recognize it.
Posted on Jul 04, 2008
May i know how do i put a SD card in ACER laptop????
like different sizes. cannot slot in.. =((((
Posted on Oct 19, 2008
3 Suggested Answers
6ya staff
SOURCE:
TampaNative
Frank Fernandez
  • 778 Answers
SOURCE: SD Card Reader Not Working on Acer Aspire 5600 Laptop
Please try another SD card as to eliminate the card as the source of the problem. As you mentioned uninstalling and reinstalling the driver in Device Manager you may want to "Roll Back Driver" there as an update could have caused this problem initially and reinstalling the updated driver wouldn't solve it.
Post back your results so that we may continue to help you troubleshoot this issue?
Thanks and good luck.
Posted on Jul 15, 2008
GuruGrundy
GuruGrundy
  • 71 Answers
Check to see that the SD card is inserted the right way, not upside down.
Posted on Mar 20, 2009
I have a acer Aspire Ei-571 laptop.I insert a sd card to it's card reader.sd card is a new one there arn't any files in that card. so when I insert the card to the reader I can't open it.so what do I need...
u more than likely need to format it first so your computer can read it.
see if it appears in windows explorer, if not copy a file then right click and send to the SD card and the option to format should appear, format it and this should fix your problem.
Oct 14, 2013 | Acer Aspire E1-571-6650 Laptop
My SD card reader on my Sony Vaio will not read the card...it seems to know its in the slot, but won't read any data and says 'insert the SD card' if I go to computer and try to read it. Any thoughts?
Take a can of air and blow some into the slot to make sure dust or dirt isn't getting the way of that reader trying to read the sd cards.
If you still get the same message try another SD card in that reader or try to see if another computer will read your SD card, if another computer will read the SD card and the slot still won't recognize the sd cards properly, then you know at that point the reader is bad. If the reader is bad, thats integrated into the motherboard so the motherboard would need to be replaced.
Nov 30, 2009 | Acer Aspire 5610-4648 Notebook
Aspire 5610z card reader doesnt show up. Vista home premium
Did you ever solved your problem? I noticed the above response is just a spam ad.
I have same problem with Aspire 3680. I recently replaced the HDD and reinstalled Vista Home, all drivers from Acer has been loaded. I even updated the BIOS, updated Vista service packs and all patches.
Sent email to Acer, but of course they want $60 per 1/2 hour. And from the past experience it will take about 2 hours on the phone. Also they have no support forum, and support sucks.
So I'm still stumped. This SD problem with Acer is the only one I couldn't resolve of all brands I've worked on.
Jul 19, 2009 | Acer Aspire 5100 Notebook
Mar 20, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Your card reader on your computer isn't capable of reading SDHC cards. You have to use a card reader approved for SDHC use.
Jul 15, 2008 | Acer Aspire 5100 Notebook
Acer aspire 5920 notebook and the 5 in 1 sd card reader
sure...I'd say you need to do a system restore to a previous point, or get new sandisk drivers from their site
Jun 12, 2008 | Computers & Internet
Blue tooth and card reader problem
i have an aspire myself and usually the card reader is on the left side of teh machine covered by a dummy SD card, push it in to click out.
the bluetooth unfortunately we had to install drivers for the bluetooth to make it work, an auto update will do the trick.
Apr 24, 2008 | Acer Aspire 3680 Laptop
Open "my computer". The SD should be visible from that window. If you right click on the SD drive and chose "explore" from the drop down list it will open a window so you can access the files inside.
Jan 28, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5610-4648 Notebook Logo
89,828 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
