Refrigerators Logo
j
joyce spada Posted on Jul 16, 2019
Cannot lower temp - Refrigerators
How do i lower temperature on Frigidaire Gallery refrigerator
the lower the numbers the lower the temp for a fridge
the higher the numbers the lower the temp for a freezer
as to lowering the already low settings
could be a problem thermostat , faulty door seals or compressor
call in a technician for a proper diagnosis
Lowering arcticpro temp.
Find in a manual in advanced setup where you can adjust the maximum and minimum cooling and max min heating. Should be a set point that someone set to where it won't go lower than 76
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
I cannot understand the dual thermostat manual (" rolling " knob type) controls . They are printed in Japanese . There are 2 temp. control knobs side by side located inside the ref. compartment / lowe
Don't think it's the temp control problem, I suspect one on the defrost elements at the top is faulty, if food starting to defrost in the cycle indicates the lower element is working overtime.
South seas spas
need more info. will temp lower? if temp lowers try setting up to 104 if desired temp will not increase sounds like you need temp adjustment switch if desired temp goes up to 104 but water doesnt
sounds like temp sensor if temp sensor is good heater element
Feb 16, 2014 • Pool & Spa
2answers
Engine overheat and no heat
Maybe your radiator is clogged.
Very hi temp coolan
raideateor cap or put a lower thermostat in .it may call for one temp. but can use lower temp.
2helpful
Temp. too hot
First off, the temp adjustment can only be made by a trained service tech, since the dishwasher will need to be reprogrammed to allow for a lower temperature in the rinse cycle but still have the higher temp needed in the wash cycle. Also, since any change in the water temp settings will require a longer wash and rinse cycle to be programmed into the unit.
Of course, you could simply lower the water temp on the water heater that supplies water to this unit, but you'd have lower temp water elsewhere and likely get cited at the next heatlh department inspection on that issue.
Since this is a commercial dishwasher, you might want to reconsider lowering the temp, since health codes and standards for commercial establishments require a MINIMUM water temperarture of 185 degrees F (85 degrees C) for proper operation and to get all the crud off the dishes, etc.
Note, the manufacturer sets these units to the higher temp, 203 degree F (95 degree C) knowing that the water will cool down quickly once the wash cycle starts and the water contacts the dishes, etc. That is also why these units have a added heater element, to help keep the water at the correct temperature needed to both clean AND sanitize the dishes, according to established health standards.
If you really want to change the water temp settings, contact your Hobart service rep and explain the reason you want it lower and see what they say.
Hope you found this very helpful and best regards!
1helpful
2answers
Temperature control
For the Kenmore, keep pushing the button and it should cycle back to the top of the temperature range.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
