Washing Machines Logo
Anthony Horgan Posted on Jul 16, 2019
S14-79 Siemens washing machine has an error of F43 ? I replaced the motor brushes but cannot clear the error? Any ideas?
I turned the dial to the 6 o clock position , hold the spin + button for 5 seconds after turning to one more position release the button then turn off the appliance but still the error exists.
5 Related Answers
A
Anonymous
  • Posted on Oct 16, 2007
SOURCE: help me to wash!!
hi
    this sounds like a syphoning problem this means the outlet /drain pipe at the back of the machine has been pushed to far into the drain upstand pipe causing the water to syphon straight through the machine make sure that the drain pipe is only part way down the drain pipe, hope this works for you
cliff
A
Anonymous
  • Posted on Feb 02, 2008
SOURCE: Hoover CA230 1300 Special Edition Washing Machine
Should you have to use un due force to get the filter undone on the Hoover 1300 special deition washing machine
Anonymous
  • 185 Answers
  • Posted on Mar 28, 2008
SOURCE: getting error code e:02 on
model number please
A
Anonymous
  • Posted on Apr 26, 2008
SOURCE: Bosch Maxx 6 WFL 2061 Front Loader W/M
brushes usually available on ebay,
if the drum rotates but does not spin, this could likely be brushes or component problem (i.e triac or relay) on control PCB. - the latter was the problem i had and this was easily spotted as a blackened track on the Relay on the pcb.
Brushes should be ~£5. - check the existing brushes first before buying them.
fitting is easy, BUT a word of warning..which you probably know anyway..
before meddling though in the machine, locate the large capacitor and with electical screwdriver and discharge all the terminals to earth first! - YOU MUST DO THIS TO AVOID ELECTRIC SHOCK!! - even if the machine is unplugged.
remove motor & undo the back plate to release old brushes.
clean of motor of any excess carbon dust, - this can eventually cause arching if not cleaned away.
reassemble and fit all plugs back.
THEN TAKE 5 MINUTES TO CHECK WHAT YOU HAVE DONE BEFORE SWITCHING ON. -
Do not rush anything - take your time.
douglas smith
  • 1462 Answers
  • Posted on Aug 07, 2008
SOURCE: My bosch washing machine wfo2865
remove back panel.remove motor wiring undo two bolts in front. remove belt. motor will pull out.
my experience of these is that often the commutator is damaged hence brushes worn
SIEMENS WM12S740EE/11 Washing Machine. HOW DO I RESET SIEMENS WASHING MACHINE?
This error can't be reset, it is a repair job. The code mostly means that the carbon brushes are end of life. You can replace them yourselves with new spare parts.
Mar 22, 2018
Please don't type all in capitals. It is hard to read and considered 'SHOUTING'.
https://www.google.com/search?q=siemens+WM12S740EE%2F11+error+f43
What is error 12:04 in Siemens iq1430 washing machine
  1. Lets try to reset it and if it happens again you will need a technician or to call manufacturer due to motor error
  2. Turn the dial to the off position, in some machines this is known as the rest position.
  3. Then turn the dial to the half-way point, this would be the 6 o'clock position on a traditional clock face.
  4. Then press and hold the spin button, while also moving the dial to the 7 o'clock position.
  5. Continue to hold the spin button for at least five more seconds then move the dial back to the off/ reset position.
  6. Finally turn the machine back on and the error code should be cleared.
How can reset error 17 onSiemens IQ100 washing machine?
How do I reset the code on my Siemens washing machine?
How to reset an error code on a washing machine by Bosch, Neff, or Siemens
  1. Turn the dial to the off or reset position (should be at the 12 o'clock position)
  2. Turn the dial to the 6 o'clock position.
  3. Press and hold down on the spin button and simultaneously turn the dial to the 7 o'clock position.
https://www.glotechrepairs.co.uk/news/bosch-neff-siemens-washing-machine-error-codes/
  1. Turn off the machine (dial to 0)
  2. Open the door.
  3. Turn on the machine on first program.
  4. Close the door.
  5. Turn off the machine.
  6. Turn on the machine on the "six-o-clock" program, which is centrifuge.
  7. Press the "option down" button and keep it pressed (This is the button left of the display)
1helpful
2answers
How to fixed a error code E43 of washing machine Siemens
This is related to the motor, and may be that the motor needs new brushes the Tacho (feedback mechanism) is broken, wiring or the motor control board. Most likely for a 6-7 year old washing machine is the brushes.
However, after changing them, you still need to reset the machine
  2. Open the door
  4. Close the door
  8. Turn the dial to "seven-o-clock" (empty/pump out program)
  9. Release the "option down" button
  10. Turn of the machine
This should reset the machine, and if everything is allright, it should work. If it does not work after changing the brushes and resetting it, something else is wrong, most likely the motor control board, or if the motor.
My Bosch Logixx 8 sensitive won't work and shows the code: F:43
Bosch Logix with error code F43 has "a motor fault".
You can reset the error code by the follow steps:
1. Turn the appliance knob to the off or reset position, 12 o'clock.
2. Turn the knob to the 6 o'clock position.
3. Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position. Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off
When your turn it back on it should have cleared the error code
Check motor connector block
Check wiring
Check motor carbon brushes
Check tacho connections
Check motor
2helpful
F43. Terminal?
motor brushes on bosch machines typically last 6-7 years its the first thing to check
2answers
F43
Hi.
If you have Bosch, Baumatic, or any other machine built by Bosch, then F43 is a motor issue:
Error F43 : Motor fault: do an emergency drain through the drain access in the front bottom side (see manual). Open door and check ig the drum rotates free when spin by hand. Disconnect power before performing maintenance.
Regards.
Ginko
Top Siemens Washing Machines Experts
vince
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
