Http://www.crovean.net/samsung-lcd-tv-power-up-problem another website on how to fix this clicking problem on samsung LCD TV.
Http://www.earthinfo.org/samsung-tv-makes-a-strange-clicking-sound has a walkthru that explains bad capacitors are the problem. Resolution requires removal of rear panel and soldering new capacitors on to the circuit board. Many responses assure that this method is successful.
Your panel could be bad.
SOURCE: hi my samsung lcd tv model le40s8, it won't switch on
if you can do soldering work, replace two 1000uF10v bulging capacitor with 1000uF 16v or 25v in powersupply board. you will save $200.
SOURCE: samsung lnt4042hx/xaa 40in lcd tv wont turn on
I concur with Lightnbaby.... had same problem... my TV LNT4042HX/XAA took 10 min to start sometimes... the capacitors on the power supply board had bubbles on top 4 of them all 10/1000Uf. Samsung wanted to charge $220+ to have a guy come out and fix. J&J parts (samsung vendor) wanted $108 for a new board. I replaced the 4 capacitors for $4.68 and the TV works fine now!!!!!
SOURCE: My Samsung LCD wont turn on
samsung will fix it free of charge .i had the same fault with mine it is 3-4 years old .phoned samsung and they fixed it for free
