SOURCE: Deluxe denim euro pro
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
SOURCE: I need a replacement Auto needle threader.
I've never had an auto needle threader work properly for very long. My suggestion is to not bother to replace it and just relearn how to thread the needle. Sorry.
SOURCE: where do I put oil in my euro denim sewing machine
I don't think you oil a sewing machine motor.
Clean out the area under the presser foot. Sometimes built-up lint can cause the motor to strain as stitching extra heavy fabric.
If the problem continues, the machine needs to be serviced by a pro.
SOURCE: I'm looking to get a manual for omega denim deluxe machine 7500 model
email these sites about a manual
sewingpartsonline.com
sewusa.com
sewvacdoctor.com
a1sewingmachines.com
SOURCE: I need to get a manual for an omega deluxe denim sewing machineModel 7500
sewusa.com
sewvacdoctor.com
