Televison & Video Logo
Posted on Aug 29, 2009
TV Picture I have a 50 inch Samsung DLP TV and the picture is messed up. It looks 3D and there are purple and green colors on it. Please HELP?
Barrie Love
Level 1:
  • Contributor 23 Answers
  • Posted on Aug 29, 2009
Barrie Love
Contributor
Level 1:
Answers
23
Questions
0
Helped
12491
Points
70
The prism has gone bad, you need a new light engine.
What part fails to make distorted or wrong colors and over all dimmer picture on a DLP TV?
You are correct that oit is the color wheel. I wcannot give you a part number at this time because you have not supplied the model number of the set. I hope this helps.
Samsung dlp HL-R5067W sound no picture
Check for open or leaky capacitors look for bulge on the top of caps
Dlp tv color goes fuzzy and green
Its probably unrelated to lamp, take the lamp out, try it again and look into the lens, if its still very green the projectors electronics are failing. The projector generates pictures as 3 streams of info Red Green and Blue. It looks like the projectors red and blue electronics are failing, but the green is working.
3helpful
I have a 50" Phillips
Check ur owner manual or call Philip support Tech. ask it this tv model have a colors wheel design into it tv.Not sure for a Philip model tv 50" DLP tv,but the Samsung model 50" DLP tv this problems alway causes by a dying colors wheel that design into it tv.Which the colors wheel it is warp worn out and spinning off of it motor mount axis to cause grinding noises and tv colors to mess up and flashes or have flashes Black & White within it picture.
I have a Samsung HL-N4647W 42 inch HDTV DLP TV and the screen is blurry and out of focus with a black curved block across the bottom. what can I do to fix it?
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Picture is not showing correctly. Color seems like it is going out. For example the color green does not show up as green.
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to solved the tv picture convergence problems.Try website like Tvrepairworld.com to buy a whole refurbish convergence board for the replacement.The Akai/Samsung DLP tv used the same convergence board.Or the shop,will cost u like $300-350 for parts and labors.
Hi I have a Toshibe DLP 46HM95 that I have purchased in 2004. I am having a problem with the picture color. It has a pink/purple/green tint and seems like the connection is trying to go out. I replaced the...
This problems,u have is not the projection lamp problems.The problems,u have it known as convergence problems,it dead.The colors lines R,G,B mis alignment,picture have colors shadows,pictures look like a 3D pics.The Toshiba DLP tvs have a board call a HYPER board,that the Toshiba tvs convergence board.The (HYPER-BOARD)the tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the HYPER-BOARD known as a convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u $300-350 for parts and labors.
SAMSUNG DLP TV HLR5067W
The main board is more than likely the cause of the trouble. Time for a new TV.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
