SOURCE: I am trying to replace the chain on a swinn pixie bike
see if theres a master link on the chain and take off from that way you dont have to take off the guard. the master link will look diffrent from all the other links and can normally be removed with a screwdriver
SOURCE: Chain has slack when sitting on bike...how do I
Loosen the nut on the axle and adjust the chain adjusters to pull the axle to the rear. Make sure that each adjuster is moved an equal amount and when finished should protrude an equal amount. Retorque axle to 50-60 foot pounds of torque.
SOURCE: Chain slips when in 7th
Hi.
If the chain slips when the bicycle is in high gear you need to align the rear derailleur hanger. See the picture below:
See this tutorial links:
rear derailleur video
derailleur-hanger-alignment
How to Check a Bike
SOURCE: Raleigh Campus bike, chain guard
Thanks for choosing FixYa and welcome. The chain guard does have significant value. It keeps your legs safe from the chain and it also protects the chain. If the chain pops, it comes off safely. Chain guards are made out of plastic so they are easy to penetrate through. The only way to attach it is through the frame, unless the frame already has a hole in it. You will need to get a drill and cut into the frame to be able to attach the chain guard. It all depends on the size of the bike. Some fit very well while others moderately fit. Calculate all your measurements, drill your hole(s), and attach it.
