SOURCE: water getting under fan compartment. water sprays
ac should have a slight tilt toward outside.
SOURCE: Where to drill drain hole in Dana 44 differential in 'Vette
can you take the cover bolts off ?, thats how i change my diff. fluid.
SOURCE: there is no drain hole for water to drip outside.
These are designed to retain some water in the pan. This is for the slinger fan to throw water through the condensing coil. This helps the refrigerant cool and is important to the efficiency of the unit. I would certainly not recommend drilling a hole in the bottom. The hole may cause the water to roll somewhere where damage could occur. Try instead tipping the unit Backwards before bringing it in the house.
SOURCE: Does Whirlpool air conditioner #
theres one near the back side on the outside part,they get plugged with bugs,leaves,debris,etc.,when its shut off look underneath and there is a drain hole on the bottom or on the rear ledge on either corner or both rear outside corners,make sure the unit has a slope toward the outside so most of the water drains there too,you can use a short piece of wire to clear these drain holes,if they are dirty enough you may need to unplug the unit and use a garden hose to dilute the debris so it flows out the drain holes
SOURCE: why isn't there drain holes in bottom of
It shouldn't be a problem if you drilled the hole near the rear, outer edge of the drip pan and didn't accidentally pierce any of the mechanical above it. Also, be sure the rear of the unit is tilted down at least 1/4" to 1/2", so water will flow to it. Check the drain hole periodically, as they will become clogged over time.
Thanks for choosing FixYa.
