Maytag MSD2456G Side by Side Refrigerator Logo
Anonymous Posted on Aug 29, 2009
Maytag MSD2754GR - Ice Maker quit working.
My ice maker has stopped making ice. It still is flowing water out of the water dispenser in the door and the control lever for making ice is down in the "ice" position.
Any clues?
Charles T Nevin
Level 3:
  • Master 4,070 Answers
  • Posted on Aug 29, 2009
Charles T Nevin
Master
Level 3:
Answers
4070
Questions
0
Helped
1088074
Points
13055
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Testimonial: "Good trouble shooting tips...will give them a try and see how they go, THANKS!"
Dana Newcombe
Level 3:
President:
  • Master 1,564 Answers
Dana Newcombe
Master
Level 3:
President:
Answers
1564
Questions
Helped
540425
Points
4667
It is possible that the servo motor that ejects the ice may have become faulty.
2helpful
2answers
I have a Matag MSD2458GE refrigerator. Water dispenser on the door works but, the ice maker doesn't work at all. Seems no water reaching it. Needs new filter, but no ice before replace filter light.
According to your user's manual, "If water flow to the ice maker or dispenser decidedly decreases or if an objectionable taste or
odor returns,change the filter sooner than
recommended."
"Leave the refrigerator door open while removing and installing filters or plugs; this will prevent water
from flowing through the system and running into
the fresh food compartment.
• A newly installed water filter cartridge may cause
water to temporarily spurt from the dispenser"
Automatic ice maker not operating
the stop arm in OFF (up) position
•the water supply turned off
•the water pressure too low
•the freezer too warm
Ice dispenser not operating
ice jam in the dispenser
•ice maker not operating
• lock switch on (see page 11)
Water dispenser not operating
• water pressure too low
• lock switch on (see pg. 11
To locate an authorized service company in your area,contact the Maytag dealer from whom your appliance was purchased; or call Maytag
Appliances Sales Company,Maytag Customer Assistance at the number listed below. Should you not receive satisfactory warranty service,please
call or write:
Maytag Appliances Sales Company
Attn:CAIR
Center
P.O. Box 2370
Cleveland,TN 37320-2370
U.S.
1-800-688-9900
CANADA
1-800-688-2002
U.S. customers using TTY for deaf,hearing impaired or speech impaired,call 1-800-688-2080.
2helpful
4answers
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Ice maker quit making ice
There are repair instructions available for this particular ice maker at www.AnyoneCanFixIt.com Specifically, you should locate it at www.anyonecanfixit.com/household.htm
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
1helpful
Ice maker in Kitchen Aid stopped making ice
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
2helpful
Amana Side-by-Side Fridge Model SBD21VPSE Problem started when water stopped flowing from in-door dispenser and ice maker stopped making ice. I emptied fridge and freezer, left unit off for several...
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
1helpful
2answers
Ice maker not making ice refrig.model#gsc23kswc ss
Check the following suggestions from repairclinic:
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
