2005 Lincoln LS Logo
Posted on Aug 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
AC cools then blows hot air, tempature needle goes up & down
AC cools for a few minutes then it blows hot air from one side it then goes to the other side. Then it will start cooling again, get hot, start cooling. Then the engine fan will be on making a loud noise. The temperature needle goes up then down and the SRVC(P) light comes on. When I take it in to get checked, the AC works fine. Can any body help?
  • wpoulard May 11, 2010
    abs traction control light on
Ronny Bennett Sr.
Level 3:
  • Lincoln Master 6,988 Answers
  • Posted on Aug 29, 2009
Ronny Bennett Sr.
Lincoln Master
Level 3:
Answers
6988
Questions
Helped
2287784
Points
21993
Sounds like the thermostat is trying to stick,and is causing the engine to over heat,therefore condenser is not cooling the freon down enough to cool.Have the thermostat changed and the cooling system bled out,this is most likely the cause.
Air conit/2002 buick rendezvous
was system evacuate by pumping it down using vacuum pump to remove all moisture out of the system.most time of the time when i work on AC system you have pump it down from 30 minutes to a hour.pump it until low pressure gauge read 30 hgs in the green area.i shut down vacuum pump close off manifold gauge valves see if low pressure side reading stay at 30 hgs or drop if gauge needle stop dropping have leak in the AC system.if all is good you have temperature air door problems.air door not opening all cool air to circulate through AC vents.
2008 V6 3.9 pontiac montana still over heating
Hi, Yes you have an air lock in your system, you may get this sorted by 1/. Removing one of the cooling hoses & try to blow with air.
2/. Drain all the system then put your heater on inside the vehicle & have the engine running & refill the system Start to do this from a cold engine. Please leave me feed back: Malcolm Campbell, Thanks.
2helpful
Ac blows cold then hot air
Is the compressor running when it blows hot air ?
1helpful
2answers
AC blowing hot air one side & cool air other side
If it has dual zone temp. control it is most likely the heater control panel.
I have a 2000 Dodge Ram 1500 that will blow cold and hot air for only a few minutes. After that is only ambient air temps. It is a 5.7 ltr, automatic with only one set of climate controls. The heater core...
you say it will blow cold and hot air for only a few minutes. You don't say but I assume you mean will blow cold a few min. when turned on AC max , blow hot only a few min. when turned to heater hot. Assuming thats the situation and you say AC charged and shows good on the low side -you should charge the AC to a full charge on the low side will cause problems with the AC air compressor kicking on and off. I suggest while the engine is running and turned to AC cold max watch the AC air compressor clutch to see if it does indeed kick on and off if so charge completely. As far as the heater make certain you coolant is all the way to the top and the best way to do this is when engine is completely cold remove radiator cap and fill completely and completely close cap then fill overflow container just to the cold level. That should fix your problem.
6helpful
AC will blow cold air for a few minutes then start blowing hot air, cut the engine and start it again and blow cold air for a few minutes then start blowing hot air again. Just filled up the freon and the...
you have moisture in the system this causes your expancion valve to freeze up an stop working, thats why it works for sort time and when it de-freezes stars working again. you need to do a EVAC & RECHARGE with a good AC service equipment, specially attention to pull vacumm por at least 20minutes so you get all moisture out of the system.
Good luck
1helpful
2answers
I have a 2006 elantra and whenever i slow down or stop the needle goes into the red zone and the a/c blows hot air. when i drive faster again the needle goes back to normal and the a/c blows cold air...
your electric fan for the AC is not working for whatever reason so when idles its all getting hot the engine and the AC system .This sort of work can be difficult to diagnose correctly and a code reader is about as good as a bible at mosque so seek the advice of a skilled mechanic who should be able to pin point the fault in seconds
1helpful
2answers
1999 Alero: where is the a/c control tempature :problem is wh...
WELL TURN ON AC MAX COLD HIGH TO SEE IF COOLANT FANS TURN ON.IF NOT YOUR REFRIGERANT SO LOW THAT THE AC REFRIGERANT PRESSURE SENSOR WONT CLOSE CIRCUIT TO TURN ON COOLING FANS.MEANING YOU NEED HAVE AC CHECKED AND CHARGED.ALSO CHECK COMPRESSOR FOR POWER IF NOT YOU HAVE BLOWED FUSE OR BAD RELAY.IF FUSE AND RELAY GOOD YOUR AC COMPRESSOR CLUTCH COIL OPEN OR THE AC CONTROL SWITCH IS BAD.IF COMPRESSOR IS RUNNING WHEN YOU TURN ON AC YOUR AIR TEMPERATURE ACTUATOR NOT WORKING.
Hot air blows but cools down in 15-20 seconds.
You likely have a restriction in the heater coolant hose circuit - perhaps a coolant control valve not fully opening, or a kinked hose.
Insufficient coolant volume is flowing to keep the heater core hot.
Try back flushing the heater core system with a garden hose to check flow.
Top Lincoln Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Lincoln Expert? Answer questions, earn points and help others
