Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to some different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then you may want to consider calling a professional plumber. He may need to replace the drain valve or hose.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Thank you for contacting fixya.com.
There are various factors when a dishwasher wont drain water
completely.Such as clogged drain hose,worn belt,pump assembly,bad
motor,defective timer,drain valve etc.Please check the bellow links to read the
article thoroughly to troubleshoot your problem:-
http://www.partselect.com/dishwasher+water-wont-drain+repair.htm
Please get back to us if you have further query else please accept
the suggestion.
http://www.repairclinic.com/Dishwasher-Troubleshooting?red=Dishwasher-Repair-Help#thewaterdoesntdrainfromthemachine
you have further query else please accept the suggestion.
