Right click printer properties and select online. Start /settings /printers. Offline can also indicate a connection is not available - this occurs with demo versions of printer software. When the demo expires, the printer goes offline. The fix is to just use windows networking and shared printer.
It is a serious problem that you are facing but just following these steps you can resolve it easily. If you find your printer in an HP printer offline situation then it can of great trouble. However, you are lucky as we are here to help you to get your printer back online that too with the help of some easy steps.
First of all, make sure that your printer and system are turned on and if you are using a wifi connection then they should be connected to the same network. This is quite a common point but often people overlook it that results in this offline status appearing even when the printer is online.
or you can visit here https://www.myprinterisoffline.com/hp-printer-offline
You might be dealing with hp printer problems due to the several reasons. check out this article and follow the instructions to fix the problem.
How To Fix My Hp Printer is Offline Problem HP Printer Says
If
you need more help come back.
Post
/ thumbs / testimonial are welcome!
