yes...put kit in caraburators..replaced filter in carberators before i did this it would not even idle...after these repairs idles good starts easy still no power ...will run 27 miles per hr but only for 20 to 30 minutes..have also replace plugs...was suggested i check trigger coil and statter not sure where they are locatedyes...put kit in caraburators..replaced filter in carberators before i did this it would not even idle...after these repairs idles good starts easy still no power ...will run 27 miles per hr but only for 20 to 30 minutes..have also replace plugs...was suggested i check trigger coil and statter not sure where they are located
have replace filter....put kit in carburators, changed plugs, would not idel at all before doing this was suggested check trigger coil and statter not sure were locatedhave replace filter....put kit in carburators, changed plugs, would not idel at all before doing this was suggested check trigger coil and statter not sure were located
95 yamaha wave runner would not idle replace filter kit, spark plugs, filter.. now will idle, starts good, will only go 27 miles per hr for 20 or 30 minutes95 yamaha wave runner would not idle replace filter kit, spark plugs, filter.. now will idle, starts good, will only go 27 miles per hr for 20 or 30 minutes
You can't post conmments that contain an email address.
Could be crankshaft position sensor ! after a crank sensor is replaced it needs to have a relearn done , Dealer or some other independent repair shop . Take it an have it checked out , unless you have a factory scan tool or a professional type scan tool .
find where throttle cable attatches to carbs and on that wheel there is a lip on the inside and a screw should be there that you adjust the tickover !! P...
An engine that dies under load but starts ok and idles ok has a fuel blockage in the main jet . Possible from water in the fuel in the carby. Water will not pass through the jet and blocks up the hole A trick that is used is to place a pint of metholated spirits in with the fuel. It breaks down the surface tension of the water and allows it to pass through the jet.
