Cleaning of condencer
SOURCE: pontiac torrent headlight burnt out? Can I replace it myself?
yes you can replace it. the bulb is removed from inside the engine compartment. if the burnt out bulb is on the battery side you will likely have to take the battery out. the socket generally turns about a quarter turn or so... have a look to see if there is a large ring that you turn and remove first.
One important detail do NOT touch the bulb with your fingers as it shortens the bulbs lifespan.
Robert
Please take a moment to rate this solution thanks
SOURCE: How do you reset the check engine light on a
disconnect the battery for 5 minutes, this will reset the light, but if the problem that turned the light is no repaired the light will come on again in a few days.
SOURCE: Where is the fuse box in a 2006 pontiac torrent
The fuse box is located under the hood. Look for a black plastic box under the hood. Open the top of the box to access the fuses. There is alos a fuse puller tool amoung the fuses in the fuse box. Consult your owner's manual for more info.
SOURCE: looking for a serpentine belt diagram for a 2006
Please don't forget to rate. Thank you:
Accessory drive belt routing—3.4L engine
Testimonial: "Thanks, this is perfect to have since the sticker is missing. Good diagram."
SOURCE: TORQUE SETTING ON FRONT WHEEL BEARING NUT ON 2006
Hello, here is the torque spec for front hub bearing
Strut to Steering Knuckle Bolt and Nut
180 N·m
133 lb ft
Tie Rod Retention Nut
50 N·m
37 lb ft
Wheel Bearing/Hub Mounting Bolt
130 N·m
96 lb ft
Wheel Drive Shaft Spindle Nut
205 N·m
157 lb ft
