Nintendo Pokemon FireRed for Game Boy Advance Logo
Posted on Aug 29, 2009
I can't use any hm's and tm's in fire red
When i open tm case there are some strange letters and numbers even if i open tm case a player card crasher but if i try to use anything whole game crashes
plz tell me what to do !
sry for my english :P
Anonymous
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on Apr 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
11
Questions
0
Helped
4256
Points
20
Well im a kid so i would know how to do this first try to take out the game and blow into it then start the game over from the load menu then try to access the tms and hms
What grafic cards 945GCT-HM suports
YOU Can Visit The HP.com and go to support and downloads and put the model number which is 945GCT-HM and you will get the drivers just download the latest one available and done.
Leaking around heating element posts that protrude through dishwasher body
Some dishwashers like your model number are under recall for a potential fire hazard due to water leaking through the heating element posts onto the wiring.
Your serial number must begin with the 2 letters listed . Below is the list of recall serial numbers: FL, GL, HL, LL, ML, VL, ZL, AM, DM, FM, GM, HM, LM, MM, RM, SM, TM, VM, ZM, AR, DR, FR, GR
Call the phone # below or check out GE recall website. What GE does is replace the element and gaskets, unless there is burnt or arcing visible on the wires, they may replace the dishwasher.
www.geappliances.com/products/recall
GE has determined that an electrical failure in the dishwasher's heating element can pose a fire hazard. GE will provide a free repair to all consumers with units affected by the recall. We ask that you not use your dishwasher until it is repaired and to disconnect the electric supply by shutting off the fuse or circuit breaker controlling it and inform all users of the dishwasher about the risk of fire.
Consumers who instead wish to replace their dishwasher with a new model can receive a rebate towards the purchase of certain new GE and Profile brand dishwashers. Consumers can use a rebate of $75 for the purchase of certain GE front-control plastic tub dishwashers, or a GE rebate of $100 for the purchase of certain GE front-control stainless tub dishwashers or GE Profile top control dishwashers. See the rebate form for eligible models.
GE is aware of 15 reports of dishwasher heating element failures, seven of which resulted in fire and smoke damage beyond the unit. No injuries have been reported.
The model and serial numbers are important, as not all dishwashers are included in the recall. Look at the inside on the front left side of the dishwasher tub to find the model and serial number.
This recall is being conducted in cooperation with the U.S. Consumer Product Safety Commission, which will also monitor the effectiveness of the recall program.
Recall Hotline
866-918-8760
Monday through Friday, 8 a.m. - 5 p.m. ET.
Before calling, have the model and serial numbers on hand.
Customer Care
2answers
Need to replace my dryer timer M460-G
The problem is that the new M460-G timer does not have the same terminal letters as the old one (because there seem to be a variety of sub-models under the M460-G name providing varying options such as an "air dry" function). However, I've at least been able to provide the basic timed heat function using a different M460-G on my old Frigidaire Crown Gas Dryer M/N FDGB23RGS2 . To do this, figure out the terminal functions by rotating the M460-G switch and measure with ohm meter and also inspect wiring diagram (mine was at appliance pros dot com).
On Frigidaire Crown FBGB23RGS2 Gas Dryer:
The original M460-G is wired:
Terminal / Function / Color
A / Gas / Org
B / Line voltage / Red
C / Motor / Wh
Timer wired between TM and C
AD / Auto Dry / Pink
TD / Start Switch and Motor / Tan
On other M460-G Gas Dryer timer (from mystery Dryer), I wired it to into my Crown dryer as follows:
Terminal / Function / Crown Dryer Wire color
BU / Line Voltage / Red
BK / Motor / Wh
R / Gas / Org
V / ? / No Connection
Timer wired between TM and BK
WB / switched on while Motor & Gas / Tan
OR / ? / Pink (figured it was safe)6b1460b2-ed5e-4c5d-b06b-c654e59e7487.jpg
I have canon g1 3.3 i turn on and it flashes letters CF what does that mean
Strange problem this one. Could mean insert a Compactflash (CF) card or that the CF card is full of maybe even Custom Functions are set. A photo of the display would help me better to solve the problem.
1helpful
We lost the instructions for word rummy
Simple Word Rummy:
Deal 7 cards per player. In a turn, a player: draws 1 card from the draw or discard pile; plays one meld from the hand or adds to a meld on the table; and discards one.
Melds can be 3+ of the same letter; a straight of 3+ letters in a row; or a word of 2+ letters of the same color (unless there are 2+ of the same letter in the word). Adding to a meld can extend the set or straight, or change its type (straight ABC + S to word CABS), or even flip them to the other color and letters.
The round ends when a player empties his hand after discarding. He get the total of the numbers on all cards in hand of all opponents. Each player with a meld of 5+ cards gets 50 points bonus. Game is 500 points.
Feb 02, 2011 • Toys
Need firing order for a 83, v6
My Chilton book lists 3 V6's for that year. Check your VIN number. The eighth number or letter in is the engine code. This will give you the firing order.
If the letter is an X or Z or W the firing order is1-2-3-4-5-6. Standing in front of the crank the odd numbers are on the left and even ones on the right, front to back. #1 on the distributor is at 4-5 o'clock position and it turns clockwise.
If the letter is E or L or B or a 3 then the firing order is 1-6-5-4-3-2. Standing in front of the crank the even numbers are on the left and the odd ones on the right, front to back. #1 is at 9 o'clock on the distributor and it turns clockwise.
You probably will be using the first order I put in but I'm not 100% positive on that. That's why I gave you the other one. Hope this helps.
Tm dive
Its kind of lame, but yea, its not in the Sinnoh Region. Thats why you cant migrate pokemon that have HM moves. Thats one thing I miss from R/S/E. So in D/P they dont have it as either a TH or an HM.
LCD monitor image
I just had the same problem! Was afraid I needed a new video card. (--a suggestion found on another forum.) But a friend suggested a low tech solution. After turning the computer off, I opened the CPU casing and blew pressurized air inside to clear the dust out and the problem went away. Hope this helps.
Computer Motherboard
open the case, clear the cmos for 1 minute, set the cmos to normal and boot.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
