SOURCE: Smart lock access code on tv
A model number for your Magnavox TV would be helpful because the Parental Control Reset procedure varies. There should be a sticker on the back of the TV showing the model number. If you have a newer LCD model, the unlock code is usually 0711. Ignore any "Incorrect" warning and enter 0711 again. Then set or clear the Parental Access Code.
SOURCE: TV Tuning on ALBA TV with DVD player
you start with tv,dvd mode to your remote control when you have alread make sure your in tuner you hit menu mode and show you the instruction select arrow shows _ + try it.
SOURCE: need code for URC-4600B00/TV model #DU1301
Here's the link to codes for your remote. Look under Orion, Sansui, Emerson, and Durabrand.
http://www.hifi-remote.com/ofaold/acc3cod.html
SOURCE: Tuning an Accoustic Solutions TV
hi go to this site selct user manuals and ur model and get the full manual there
regards
http://www.nodevice.com
press the preset button on the front panel once then (TV should be on) the on the screen there should be words the likes of (Auto VHF 1 60.00mhz) now the Auto stands for auto tuning VHF stands for its frequency where its going to search the 1 stands for the channel where its going to start with 60.00mghz stands for the lowest signal to which its going to start now that you have understood all that just press the volume up button then it will automaticly locate all your working channels leave till it stops for when does it will start from channel 1 to which I believe that you be able to see the channel working so press the up button on the channel button to check the rest of your channels hope this will solve your problem!
