How do I remove the crown from this kind of watch without breaking it?
All Calibers are different. If you look on the plate where the stem protrudes from the movement you should see a small button that has a dimple in it to prevent your tweezers from slipping when you push it down to release the stem.
Donald McPherson C.W.
www.finewatchmaking.com
After you get the stem out with the crown on it you then will need to hold the stem and rotate the crown counter clockwise to remove the crown. This should work for almost all watches.
Have a vintage rotary chrono moonphase and day calandar was jumpy!!!
Virtually makes hour hand jumpy too.
I need a schematic diagram to see how all the bits go together.
Cheers
ian
