Brand new Magic chef microwave AFTER 1ST USE
proceed with common sense tech. God bless you
Touchpad dead If you have a stuck
key or non-responsive key, most of the time you will have to replace the
keypad for this microwave oven repair. If your keypad is connected to
your control board by a flat ribbon wire, try disconnecting it and clean
the silver contacts with an ordinary pencil eraser. After cleaning,
plug it back in and try it. If it doesn't fix it, replace the keypad
unit. Some units actually have keypad tests to confirm your diagnosis
of a bad key.If your keypad and control is the same unit, replace
that unit. Another note, unlike stove/oven keypads and controls, most
microwaves do not have error codes or tests to distinguish whether it is
truely the keypad or control. Most of the time, it is the keypad that
needs replacing, but a small percentage of the time it can be the
control. Check the tech sheet if they can point you to the right part.
