SOURCE: Sanyo DS27880 27" TV, Dish signal lost after tv turned off, doesn't return
checks should on your tv tuner it could be bad.IF circuit should also be check and the video section call in the tech to make checks on your tv.and to do repairs on your tv.
SOURCE: can't get reception. Unplugged
Getting reception for you is not something we can conjure up. Therew could be a million resons why u cant get reception including a damaged TV receiver or a damaged Disk receiver, broken coax etc etc etc.
You can buy a meter that connects in line between the dish and the Tv that will measure any signal being received for about $20. But is no guarantee that the TV is not faulty even if you see a good signal on the display.
Often better to engage a Tech on site than fall off the roof and become a para or electocute yourself playing around inside the TV.
Life is more valuable than saving a few bucks on a tech!
SOURCE: dish network control not working on 2nd. tv
You have a dual receiver and 2 remotes. make sure that receiver is in dual mode. That you press the sat key on remote 2 if it will still not operate take remote 2 to the receiver. With remote #1 press the menu button twice you should then be on they system info screen. Pick up remote #2 press and hold sat key until it blinks press record 3 times . press red power button and if tv2 light goes off and on the remote should work again for tv2 . Use remote #1 press select exit screen,
SOURCE: we move the tv from
Rescan all the channels?Hook the tv and the satalite signal cable in the tv and dish network box correctly check?Go to tv menu.Goto SETUP,pick CH. pick option CABLE enter to rescan all channels.This should have all the channels,belong to the package u order.
SOURCE: My dish network remote for tv 1 is not working. My
Hi this is Phillip Chang from DISH Network. Sorry to hear you have been having that remote issue, let's get that fixed. The problem may in fact be that your receiver is currently in Single Mode when you want it to be in Dual mode. Check that the amber "Mode" light on the front panel of your DISH receiver is lit on the right hand side (indicated by two overlapping squares), if it's not then we want to press the mode button, located behind the door on the right side facing the receiver. Most times this fixes it.
Let me know if you have any follow up questions.
