Archos 605 WiFi Digital Media Player Logo
Posted on Mar 04, 2018
Archos 5 error 101 recovery
New out of the box, i plug it in ti charge. Get this error. the volume ctrl does select or move the selection bar.
Tried the reset and nothing
Worst I cannot select any of the options. (Repair, format ,calibrate, no)
and the Archos support site blows!
4 Related Answers
Anonymous
  • Posted on Nov 11, 2007
SOURCE: HELP!
The Archos site tells you how to deal with the problem - you need to download to your computer the laterst version of firmware (operating system), copy that to the root drive of your archos, leave it connected and ehn update the firmware. Worked for me - but I did lose everything on the drive
Anonymous
  • 5 Answers
  • Posted on Jul 24, 2009
SOURCE: recovery code 101
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 5 or 7:
1- Plug the unit to you computer via the USB cable.
2- The unit should start automatically and open the following page:
3- From the recovery console (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the volume control on the right of the unit (Do not press "Format" at any time)
5- Now that you are on "Repair" press the on and off button, shortly to validate your selection
6- The unit will go to "Plug the unit etc…" but it is already plugged from point 1 - DO NOT press anything anymore on the Archos
8- Wait until Pc should recognizes your Archos (around seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 5 or 7
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 5 or 7 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the USB cable until the process is finished
4- when done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Anonymous
  • 5 Answers
SOURCE: Just got Archos 5 goes into error 101...
Hi there, these instructions are for the archos 705 but they are the same for the 605.
B) The Archos 705:
1- Connect the unit to its power source.
2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
3- The recovery mode will start (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
5- Now that you are on "Repair" select it to validate your selection
6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
D) On the Archos 705:
2- you are done! The Archos 705 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the power cable until the process is finished
4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
Anonymous
  • 492 Answers
  • Posted on Jan 12, 2010
SOURCE: my archos is showing recovery code 101
It is indicating that there is a hard drive fault. Here is another users suggested method to clear the fault.
Following some extensive use I switched it on one day to find that it hung on the Archos home screen and kept going in a loop. Luckily I could see the red HDD light flickering so knew that the Archos was trying to do something and that the HDD was recoverable. When I entered into the recovery mode I found that I had an recovery code (101) which indicates a HDD fault.
I used the following steps to recover the HDD:-
1. Connect the archos to the PC using the USB cable (the unit will start but will need to be shut down again by pressing the power button)
2. Press the power button and the 'lock' button together for a few seconds and you should get a basic recovery screen
3. Scroll down to repair disk and select
4. Click on done and wait for a few seconds and you will see the archos as a drive in 'My Computer' (Note that this does take a few minutes)
5. You now need to back up your data, movies, music, widgets etc as the next step is to format the Archos HDD which will wipe it all.
6. Disconnect the Archos, turn it off and then turn it back on again by pressing the power and 'lock' buttons together.
7. Scroll down to format disk and select. The Archos will now delete all files on the HDD and you will get a message asking to connect to a PC and install the update file. This is the firmware file that can be obtained from the Archos website. You'll also notice that the recovery code has changed from 101 to 108
8. Connect the Archos to the PC, wait for a few seconds and you will see the archos as a drive in 'My Computer' again.
9. Drag the firmware update file from your PC where you've downloaded it to directly on to the root drive
10. Click 'done' on the Archos and it will begin to update the operating system.
11. Once this is complete then there should be an update successful message, select done and the archos should restart giving you the nice bubble screen and asking if you want to enable USB.
12. Note that the Archos is now in a 'factory built' condition so you'll need to adjust settings etc according to your preferences.
13. You can now start the long process of transferring your files back to the Archos.
Archos 101 wont turn on
System recovery
If your ARCHOS does not respond correctly or does not start properly, you can try to remedy this situation with a system recovery. Be very careful with this as there are options to erase all the data on your device.
To enter into the Recovery screen
- Turn off the device and wait 10 seconds.
- Press and hold the volume + button while powering on the device.
- Keep the volume + pressed until the Recovery mode starts (white screen).
- To move from one option to another, use the volume buttons. To select an option, press the ON/OFF button.
Recovery mode options
No: Cancels the system recovery.
Update firmware: Allows you to connect your device to a computer in order to copy the latest .AOS file (operating system) to your device and then install it.
Repair System
: Attempts to repair the file structure on the internal memory. This does not erase any data.
No: Return to main recovery screen.
Force Touchscreen Calibration:
Select this and then select no to leave the recovery screen. Upon restarting, the ARCHOS will immediately start the touch-screen calibration utility.
Check Disk: Check and repair the system partition if damaged.
Start USB MSC: Allows you to connect your device to a PC to access the internal memory.
Format System: Formats the internal memory. All data (music, photos, videos, etc.), applications and settings are erased. "
copied from the Archos online manual
1helpful
Bought my tablet as a window display item. archos 101 How to end demo mode ? Thanks
Power off by holding the power button for 10 seconds.
Press "Volume +" button and power it on (press power button to start while holding "volume +" until the tablet displays recovery mode. Select the "Format System" option.
I reformat my archos 101 tablet, now all the files are gone, when I turn it on all I see is Archos A101IT Recovery, can you please help. Thanks.
20.3.1. To enter into the Recovery screen - Turn off the device and wait 10 seconds.
- To move from one Go to this web page to see the latest on-line version of this manual. Go to this web page to see the latest on-line version of this manual. Go to this web page to see the latest on-line version of this manual. Go to this web page to see the latest on-line version of this manual.option to another, use the volume buttons. To select an option, press the ON/OFF button. Go to this web page to see the latest on-line version of this manual.
20.3.2. Recovery mode options No: Cancels the system recovery.
Repair System
Select this, set your device down, start the calibration, and don't touch it. It will re-calibrate the screen. After the calibration is complete, select No to leave the recovery screen.
HOPE IT HELPS AND GOD BLESS!!!
27helpful
3answers
Archos 101 internet tablet cant get out of demo mode
Try this:
Power your Archos 101 off by holding the Power Button for 10 seconds (this fully shuts it down).
While holding the Volume + button power it back up (tap power button to start up, hold volume until the tablet enters recovery mode, you'll see a series of choices instead of the demo mode).
Choose the Format System option.
When this process is complete make sure not to select Demo Mode as Android boots and the Archos 101 gets up and running.
2helpful
My archos is showing recovery code 101
Stuck on the ARCHOS Screen and it won't do any thing
B) The Archos 705:
C) Computer
10helpful
3answers
Recovery code 101
C) Computer
15helpful
6answers
My Archos 5 is displaying a Code 101 error message. How can i fix that? I can't get to go past this message?
Your system is somehow corrupted, could be music downloaded from the net, whatever it is easy fixable.
C) Computer
3helpful
B) The Archos 705:
C) Computer
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
