An application touchflo (process com.htc.launcher) has stopped unexpectedly. please try again.. when i force close the problem will arise again... and it is keep on coming.... please give the solution
Htc evo has stopped woking says htc,sense launcher process is not working
I have the same problem; i even returned in to the shop to get a new one which has exactly the same issue. It's happening when the weather-widget with the animations is on. And only when I'm in my own town, 's-Hertogenbosch. It's almost as if the widget has trouble with the name of my town. Where do you live? Is it possible that you're in the same situation as me?
Greetings from Holland,
Joris
Try a soft reset if it does not work back up your data and do a hard reset! good luck but it sounds like somthing is corupt in the rom!
Power handset 'Off'.
Remove the Data Card, if applicable.
Press and hold Back and Home keys.
While still holding Back and Home keys, press power button.
I have the same problem, also in 's-Hertogenbosch and I have reported the issue to HTC.
fucked up my phone with my backup now i can't get into my phone, do i nave to root it to fix the problem and how the **** do i do that?
not usefull
Every. Time I try to play it brings up an error _unexpected problem and you have to force closed
the application samsung home has stopped unexpectedly
