Question about Frigidaire Washing Machines
Frigidaire washer ATF6000FS door won't lock. It seems to work fine, just did a load. Went to do second load and would'n't lock. I got it to lock and it started, but then unlocked and won't relock.
SOURCE:
SOURCE: FRIGIDAIRE FRONT LOAD WASHER
I too had the same problem, I closed the soap tray and a magnet popped out and got stuck to the door. Same problem with it acting like it was going to start and then beeped. This is where the magnet goes, just stick it back in, its held in with pressure (barely) :)
I took the whole control panel off to locate the magnetic reed switch, then just reverse engineered where the magnet is supposed to go on the soap drawer.
Posted on Sep 26, 2008
  • 11 Answers
SOURCE: 1998 Jetta Passenger Door Won't Unlock
I had a similar problem with my son's 1998 Jetta K2 4 door. I sprayed loads of WD40 into the locking area from the end of the door through the clip slot, worked the mechanism sprayed some more and finally it start working. My mechanic said these are very prone to moisture causing rusting on the moving parts.
Posted on Dec 02, 2008
  • 33 Answers
SOURCE: The door lock on my frigidaire washer
The locking mec is jambed or broke easy fix hope this helps
Posted on Apr 29, 2010
  • 121 Answers
SOURCE: ge front loading washer door won't unlock
I had the same problem. I didn't want to spend the money or go to the trouble of replacing the whole latch assembly with the GE latch repair kit.
I found that the plastic latch piece screwed to the door had broken and one of the two latch "fingers" was stuck in one of the latch openings on the washer. I fixed the problem by removing the broken part from the washer and drilling and countersinking very small holes (1/16" I think) in the plastic latch piece on either side of the "latch finger". I then put the broken off piece back in place and drillled pilot holes for #4 sheet metal screws in the door where the latch is located. The door liner is plastic and I think I used a 1/32 inch drill bit. I reattached the broken latch piece with two 1/2 inch stainles steel #4 flat head phillips screws from Home Depot. The screws hold the broken latch piece in place as orinilally positioned.
The repair is working fine and the door now latches like it did before the latch part broke
Or: http://www.appliancepartspros.com/part_details.aspx?image=0&part_id=2045520&pn_=WH10X10002 Same part cost $200 direct from GE
Read more: http://forum.appliancepartspros.com/washer-repair/8379-ge-washer-front-loader-door-wont-stay-latched.html#ixzz1LmNUKfTN
Posted on May 08, 2011
  • 251 Answers
SOURCE: The door on the washer
HI - UNDER THE CORNER OF THE SOAP UNIT YOU WILL FIND A GREENISH YELLOW NYLON - PULL ON THAT TO UNLOCK THE DOOR.
Posted on Jun 24, 2011
How to disassemble atf6000fs?
Hey friend, I appreciate your for the post!
I understand you are trying to disassemble your Frigidaire washer, ATF6000FS. I have researched your error code "E90" and that seems to be an issue with your main control board or user interface board. These intricate parts do require precision and patience, therefore when replacing the exchange of electrical components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Chris
Aug 07, 2014 | Frigidaire ATF6000FS Affinity 3.5 Cu. Ft....
Why does my washer not start?
pull out the plug first
check the wire to the pump are on the pump
Jul 21, 2014 | Frigidaire Latest ATF6000FS ATF6000FS...
What does E23 mean?
Hello Friend, that's a great question!
If you are getting error E23 on your Frigidaire washer, it usually means one of three things: your drain pump relay has possibly failed, a wire may be disconnected from the pump, or your main control board probably needs replacing. One of the best ways to determine if this is a false error code is to reset the power to your appliance by either unplugging it or flipping off the breaker for about ten seconds. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Why does my fridgaire front loading washer will not start?
Good Afternoon Friend, this is Z. Thank you for allowing me to assist you!
Based on the symptoms you are describing, you may either have a communication error from the main control board or the timer itself may not be operating correctly. If you noticed a humming noise, it could either be a clogged drainage hose or pump that needs to be cleaned, or it could possibly have another issue with the door lock assembly. I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts.
Not working
Good Afternoon James,
I see that you are still having trouble with your Frigidaire Affinity washer, model# ATF7000E, finishing and now starting a load, even after replacing the door lock.
I would start by making sure that your washer door is completely closed.
Next I would check to make sure that your washer controls are not locked. You will see a "LOC" code if the controls are locked. To get them out of the lock mode, press and hold the "Options" and "Select" buttons at the same time for 10 seconds.
If you are still having trouble you will want to give your washer a hard reset. You can do this by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes.
Once power is restored, if you are still having trouble with your appliance either not starting or not completing the cycle, I would recommend contacting either the manufacturer or your local authorized technician. Hope this helps.
-Best Regards-
WP
Apr 07, 2014 | Frigidaire Affinity ATF7000E Front Load...
How do I go to clean cycle-Frigidaire affinity ATF6000fs
I was doing a search for infor on how to clean my affinity front load washer, and came across this infor and this did not work for me either, but when I turned my dial to rinse and spin then hit clean the clean option appeared.
Jan 21, 2010 | Frigidaire ATF6000ES Front Load Washer
My washer wont do the spin cycle. everything else work fine but no spin
The reason the washer won’t spin is due to the either of the latches on the door.
This model uses a two stage lock that latches the door when the load starts, and then when it is time to spin, the second lock engages to ensure the door is properly secured prior to beginning the spin. When this second lock engages, it also closes a set of switch contacts (the auxiliary door switch) telling the control board the door is closed and locked. If for some reason this switch is not closed, the washer will tumble during what would normally be the spin cycle until the entire cycle is complete.
On the entire Frigidaire ATFxxxxxxx line of front load washers, if the secondary door lock fails, the unit will not spin. If you suspect this is the reason your washer is not spinning, do a check of the error log and you will find an E47 error has been logged. This error indicates the control board thinks the wax motor has failed because the auxiliary switch never closed. The customer will not see this error in the display, but it will be stored in memory. A quick resistance check of the wax motor will tell you if it has failed. Expect 1K to 1.5K of resistance from most of the wax motor heaters.
After finding the E47 error stored in memory, I would request you that the switch be removed from the outer door seal spring so you could pull the switch out the front. A quick resistance check showed the wax motor was open electrically so it was no longer working. Install a new switch assembly
, reattached all the wires along with the door seal. And now the washer will wash and spin.
Thank You for using Fixya.com
Jul 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer not working properly
The reed switch has been removed from the newer washers of same model. Nothing to do with the switch. Open door and turn the drum. This has happened to me a couple times. If the drum will not turn , try putting a little force on it. Mine acted the same and it was a sock that was stuck. Didn;t know what it was until I removed the boot where the coin trap is . and found a sock hanging down from the tub. stick your fingers up it the tub( with washer unplugged) and check for any material that might be there.
Jan 17, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Frididaire front load washer won't lock
I find that I need to be extra gentle or it won't lock.  Try that.
Jan 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Affinity LTF7000ES door not staying locked
unplug the washer and wait 5 minutes before plugging it in again!
this resets the system. If this does not work then you may have a faulty door lock, latch, or switch!
An need hands on service on location
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 31, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
