ONN HDMI DVD player need drivers for my computer
Cant get the computer to recognize that I have plugged in the DVD player to the computers HDMI port
SOURCE:
Vegggie Boy
  • 28 Answers
SOURCE: Computer Won't recognize MP3/MP4 Player
Go to device manager. Remove all USB ports. Re-boot. See if that workds.
Posted on Jun 14, 2008
Ajkill
  • 2035 Answers
SOURCE: Loaded 3D Embroidery software on
Try to install the software from the download as its latest version its will prompt you to remove the old version on your computer and follow onscreen instruction you be able to install the software...........
Posted on Jun 27, 2008
  • 195 Answers
SOURCE: samsung hlr4667 dlp \ no hdmi connectivity
No, when I bought my new plazma tv, and unhooked my old DVR box, I had to go to my cable provider and inform them. they sent a signal and WHAM I was back in Biz.
Posted on Nov 10, 2008
  • 8 Answers
SOURCE: No pc recognizes the V-touch 8gb mp3 player by Visual Land
Windows xp, Vista, and Windows7 should already have a driver included for the v-touch. It's possible that if your computer has a compact flash card reader, that it maybe preventing the v-touch driver from being correctly installed. Try using the "Safely remove Hardware" to temporarily remove your cf card reader. Then try plugging in your v-touch. It should now correctly install the driver and the v-touch will show up as a new drive. In Windows Device Manager under "Disk Drives" you should see 2 new devices - "Company PNP Platform OPN USB Device" and "Company PNP Platform SDC USB Device
Posted on Dec 23, 2009
  • 150 Answers
SOURCE: I bought a Curtis MP3 player MP2012UK. It says
try using windows media player with it ... Open windows media player then plug your mp3 player in to your pc. Sometimes you have to do it a few times for it recognize it. I think if you hit the F5 key it auto refreshes ... hope this helps
Posted on Apr 08, 2010
How do I connect my view sonic 12843 to my DVD player?
Best option is to use the HDMI connector to connect the DVD player (assuming your DVD player has an HDMI port). Then make sure the monitor is set to accept the input from the HDMI port.
Feb 22, 2015 | ViewSonic Computers & Internet
How to hook up DVD player to 19' led HDTV
The modern way is to buy a HDMI Cable
Plug it in to the HDMI Port on back of DVD Player
Plug the other end into spare HDMI Port on LED TV.
Put in a DVD & hit Play
Use remote control to select HDMI port on LED TV
If it does not have a HDMI port then you need a converter box which picks up the Red & White (sound) & Yellow (viideo) and converts to HDMI standard.
Aug 13, 2014 | Televison & Video
Toshiba store and gowont playon dvd player
Does the computer recognize the 500GB Drive when you plug it into your usb port?
Click Start/My Computer and see if your 500GB drive is listed as a device, if not that's a problem.
Try using a different usb port. Also try using the 500GB drive on another computer.
If it's gone belly up, it's not going to work.
Jun 05, 2012 | Toshiba Computers & Internet
How to connect blu ray player hdmi to my laptop
1) Look at your laptop computer to see if you have an HDMI cable port. This port is roughly half an inch wide and provides both the HD audio and video signal. If you don't, you are going to use a DVI port on the laptop. This is the same port you use to connect monitors to your computer.
2) Plug the DVI-to-HDMI adapter into the DVI port on the laptop with the Blu-ray player. If you have an HDMI port on your laptop, you can skip this step.
3) Connect an HDMI cable to the HDMI end of the adapter. If you have an HDMI port, plug the cable directly into the HDMI port.
4) Plug the other end of the HDMI cable into the HDMI port on the HD television. Power on your television, press the "Input" button and select "HDMI." You can now see the contents from your Blu-ray player on the TV.
Thanks for rating
Good luck
Feb 11, 2011 | Televison & Video
I have purchased the blu ray dvd player do i need to by a coaxial jack as well as the hdmi jack
No,a HDMI cable alone will do the job.Just plug the HDMI cable one side connected to the HDMI port hub belong to the tv HDMI hub,the other side of the HDMI cable connected to the HDMI port hub belong to the Blu ray dvd player HDMI port hub.That should play ur Blu ray dvd player.U still have questions,read ur owner manual.
Jun 24, 2010 | Televison & Video
I want to connect my denon 790 to my 5:1 surround, HDMI DVD player and HD samsung 55'' LCD. what cables do i need and where to put them. thanks
You will need 1 HDMI cable to link between your DVD player and the Denon,plug the HDMI cord into the HDMI port on the back of your DVD player and the the other end into the Denon 790 HDMI port labeled DVD,then you will need another HDMI cord to go between the Denon and your LCD TV,plug one end of the HDMI cord into the Denon 790 HDMI port labeled HDMI monitor out and the other end into one of the HDMI ports on the back of your TV, it doesn't matter which one you use, just remember that you will have to change the input on the tv to that specific HDMI port when you play back a DVD and you will also have to change the Denon to DVD as your source to send the audio through the Denon to your surround sound speakers.( The Denon owners manual will help!!)
Nov 26, 2009 | Audio Players & Recorders
HDMI not working Sony BDP-S350
plug the sony player into your home network via a network cable ( should be a network port ( RJ45 port ) on the back of it and then update the firmware - unless its already the latest version, if it is then post back with any error messages or whats happening exactly when you try to select HDMI or is it greyed out ?
Jun 02, 2009 | Sony BDP-S350 Blu-Ray Player
HDMI for laptop Compaq no sound
Hello ahmselem,
There are a couple of things to try.
  1. Open up your sound display on your laptop, and make sure that the computer recognizes the HDMI port out. If your laptop came with the port, then your computer would recognize that the port is there only if you have the correct drivers installed on the laptop. You can check that in your control panel/system/hardware devices. Look for Ports and make sure that their is no triangle with an ! in it.
  2. If your computer is set correctly, then you need to make sure that your TV is set correctly. Sometimes (I'm not a TV Expert) the TV need to be configured to each port. Especially if your using a receiver. So if your TV is on the correct input channel, look at the TV's options for audio, and make sure it recongnizes that port as HDMI.
  3. To test to see if the HDMI cable is bad, take a single multi audio plug and place it into the Headset plug on the laptop, and put the other side, which should be either a red and white plug, or compoment audio plugs, and plug those into another port completely, and switch the TV over to that port, to see if you here sound.
  4. If all those fail, then test the outbound port on the laptop, by pluging the HDMI into your DVD player (if you have one) and it will pass the sound through to the TV.
  5. Without knowing your TV, and coupled with my TV lack of knowledge, I'd also suggest reading through the TV manual throughly to see if it's not some simple switch that needs to be flipped.
Good Luck
Mark
Apr 04, 2009 | Compaq Computers & Internet
TV does not always recognize the DVD player
that's a firmware problem where your tv's firmware does not handshake with your dvd's firmware. This could be from your dvd's software being to old for your tv to understand it. HDMI (TDMS Technology) still has Alot of catching up too do with 3rd generation tv's. Alot of HDMI devices still have the first gen software loaded into them. So a tv after 2005 won't work with HDMI from 2003 (1st gen). Most tv's made after 2007 have software that's "backward compatible" so they will work with first gen HDMI.
How does your tv perform outside this problem???
Feb 10, 2009 | Samsung PN50A550 50 in. Plasma TV
Samsung hlr4667 dlp \ no hdmi connectivity
Nov 10, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Ekse
