57-100 57-200, 57-300 or 400? there are 4 versions.
to what device? unstated and matters big time. BT head phones?
first is , it must have Bluetooth, most didn't then.
it was an option, then. (in fact many options)
most times its part of the wifi card inside.(and was)
or it did work before today (I lost)? means that?
then the HP Compaq driver is missing for it.
HP has it , if you download it.
the #1 cause of Bluetooth software driver failure is upgrading the unstated OS and there is no driver for that OS. (w7 to 10?)
what OS does your 57 run?
it came with windows 7, is that it?
the 57-100 PC has this driver.(Wild guess, no PC full P/N stated)
worse yet they offered 2 BT cards seen here(network drivers)
(what I do , lacking hwINFO32.exe is look at the card first.
see what is there. make and model. the pick the driver.
https://support.hp.com/us-en/drivers/selfservice/compaq-presario-cq57-100-notebook-pc-series/5059083
SOURCE: compaq presrio c700
There is one easier answer for Vista, there would be an icon in your system tray next to the clock that is Blue and looks like two triangles one on top of the other, but you may first need to deactivate hide inactive icons in your taskbar. To do this, right click a blank area of your Taskbar and choose properties, the resulting property sheet(s) should have a check box that lets you deactivate "hide inactive icons".
Next, there should be a Fn+Function key combination for activating onboard wireless (including Bluetooth) the blue icon on your function keytops looks like a vertical line with two radiating half circles on either side. Make this keyboard combination keystroke and you should see an onscreen display you can select with your arrow keys. If you see the Blue icon with two triangles you've got bluetooth, most displays have wireless plus Bluetooth in combination, select that. If you are not quick enough before the display goes away try again.
You model notebook does have bluetooth so please use the link below to see an overview with setup information for Bluetooth. Click here.
This is the link to setup Wireless on your laptop which should also include Bluetooth.
This is the link for support documents regarding your laptop.
As always, should you have further questions please feel free to comment back and also please consider that if you find this information helpful, please rate it as fixed vs helpful. It means so much to those of us who answer calls for help for free and not for a fee. Again, if you get stuck, I am here to help you, nearly all the time but, with exceptions, so please don't hesitate to comment back with any need for more assistance in helping you and I'll get back with your as soon as I can to help you get this setup for your laptop done.
Best Regards,
Worldvet
SOURCE: compaq presario bluetooth
here is a link to the manual.
http://h10032.www1.hp.com/ctg/Manual/c01116573.pdf
Please rate this solution when you can.
SOURCE: driver laptop compaq presario cq60
please send u r email ID i will send u the links for it
( siddharth )
[email protected]
SOURCE: bluetooth drivers for compaq presario c700 core 2 duo laptop
plz check in the manufacture website
