The drive belt on my Troy Bilt thoroughbred heats up when operating the lawn tractor. Belt has been replaced and pulleys are free no binding.
SOURCE: how do i replace a drive belt on a troy bilt self propelled lawn
You turn the mower over, remove the blade with a 9/16 or 5/8 socket. There is a bolt holding shroud on, 3/8 or 7/16, there are two screws by the rear wheels, 7/16 that need to be removed. Once the shroud is removed, belt can be removed and new one put on.
SOURCE: NEED A DIAGRAM OF HOW TO ROUTE A BELT ON A TROY
type in your model number to your search engine. find your model and the diagrams will be there.
hope this helps.
SOURCE: how to replace drive belt on troy bilt lawn
Go to this website, upper right hand corner and do a parts look up.
Search for your model and that good stuff they ask of you and then
choose mower housing should be there, browse the site it's really cool
and has a lot of info.
http://www.jackssmallengines.com
I did a
sample search for generic riding mower deck and found great diagram of
belt routing. Give it a try you will find same results Good Luck! Don't forget the thumbs!
SOURCE: how do i replace drive belt on a gardenway lawn
how do you install a drive belt on a 46 inch garden way troy bilt riding mower
SOURCE: Troy Bilt Horse Lawn Tractor Transmission problems
you need to screw the transmision adjustment in so that it is push all the way in to gear.
