I just ordered and received a Hot Rod Deville 212, it was used on ebay and stated honestly the reverb was causing a squeal. Everything else works great...tested it all, clean, drive, more drive, effects loop...when you turn the reverb past 1 it begins a high pitched squeal that gets louder as you increase reverb. Any ideas what is causng this?
Here is an article that might help:http://www.guitarplayer.com/article/reverb-troubleshooting/jun-09/97165 Here is the schematic:http://www.fender.com/support/amp_schematics/pdfs/Hot_Rod_DeVille_Schematic.pdf Check to see if someone hasn't reversed the input and output cables at the reverb tank. Then troubleshoot the reverb section .
