AOC L24H898 24 in. LCD TV Logo
Posted on Aug 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My son bought an AOC LCD TV (model L24H898) last month and connected his laptop and XBOX to it. Yesterday we lost internet connection and the screen on the TV went blank. Now none of the button on the TV panel or remote will work except to power it on and off. When it powers on it displays the "loading...please wait" message, then a brief AV menu followed by the "no signal" display. All buttons display a "button locked" message when attempting to do anything other than turn it on or off. Nothing in the manual addresses this or describes any kind of reset feature. I've tried holding "menu" button for 15 seconds, unplugging all the cables and nothing seems to work. Any help would be appreciated before I send it off for repair. Of course, 30 day return was up a few days ago :-(
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5656
Points
31
According to the manufacturer, to reset the entire unit do the following:
1. Press and hold "Menu" and "Channel +" on the TV. 2. Using other hand, press the power button. 3. A small screen should appear in the top left part of the screen. 4. Using the remote, select "Memory Recall" and select. 5. Power off and re-boot the computer 6. Run channel auto-scan to regain the picture.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Sep 24, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
8607
Points
37
On the tv press and hold both the + and - on the volume control and the buttons will unlock
Anonymous
Level 1:
  • Posted on Sep 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5656
Points
I bought a new AOC LCD monitor and have connected it to the hard drive but all we get is 'no signal' . how can I get a signal?
  • Dave Parker
    Dave Parker Jun 30, 2017
    This can be caused by a couple different things. •No television signal. Hook up an antenna or cable box.
    •No computer signal on the PC/VGA input. Move your mouse to wake your computer. Check your VGA cable connection (the plug may have come out or is loose).
    •Change your input selection from TV (or whatever source is selected) to PC.
Anonymous
Level 2:
  • Expert 113 Answers
  • Posted on Aug 28, 2009
Anonymous
Expert
Level 2:
Answers
113
Questions
0
Helped
30898
Points
338
Unplug unit from power for 30 mins or so
My aoc l24h898 lcd tv led light turns blue but then turns red in seconds
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
AOC L24H898 has audio, no video
This sounds like a power supply problem that causes the high voltage power supply to shut down when it warms up. A repair shop may be able to fix this.
Service mode aoc lcd tv
This sounds like a common problem on these TVs. Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. *A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
If this still does not work, perform steps 1-3, but when you get to step 4, select "EEPROM Init". Then steps 5 and 6 to power it off and back on.
AOC L24H898 - Several problems. 1)Only 3 Display modes - AV, HDMI, PC. 2)In PC mode screen is white with barely-discernable Desktop. 3) Menu button does nothing (pressing Channel + and - together lo
This sounds like a common problem on these TVs (it's happened to both of my AOC TVs a couple times). Try a factory reset:
Vertical line comes on screen
the vertical line you see in your tv is not fixable your lcd is already damage but it can be replace with a new lcd.
How reset L24H898
Hello
From Menu options come to "Option" window. Highlight "restore defaults' and press "Enter". The set will automatically restore to Factory default settings. OK.
3helpful
No tengo menu en lcd aoc L24H898
mi televisor se quedo azul se ve la imagen azul y se quedo sin sonido al presionar los botones dice " button locked"
1helpful
3answers
AOC L24H898 LCD TV
Do you have power surge or failure issues with your electricity? Try plugging your TV into an uninterruptable power supply (UPS) to get line conditioning and the continuous power.
Otherwise, I'd guess there is something else causing memory failures (bad chip or something).
I hope this helps.
Can't find AOC L24H898 drivers. Can anyone
Should not need any drivers. Just need to send video signal in correct format. ie.. 1024x768 60hz does the full screen. Trying 1280x960 will give a incorrect format message, but 1920x1080 is accepted. Strange TV... but that's the way it is.
39helpful
3answers
Buttons locked on AOC 24'
On the tv press and hold the + and - volume control buttons and the buttons should unlock.
Top AOC Televison & Video Experts
Arnie Burke
Arnie Burke
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
