Building Materials Logo
Adriaan van der Merwe Posted on Jul 15, 2019
The Eazylift Mark II garage door opens fine but does not close with the remote.
Hi there, I have a eazylift mark II garage door which runs through its limit settings fine, opens and closes automatically when done, but when I test it with the remote, the door opens fine but does not close with the remote, only a clicking sound which turns the light on. What could the reason be?
Joe Crandall
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 19 Answers
  • Posted on Jul 15, 2019
Joe Crandall
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
19
Questions
0
Helped
2786
Points
50
Are the door stop sensors aimed properly and unobstructed? Does the door opener flash when you attempt to close with the remote?
Testimonial: "Hi Joe, there are not sensors installed on this unit. On the screen the bottom part of the "U" it flashes during the clicking sound made, then goes off and no reaction from the motor"
5 Related Answers
Anonymous
  • 18 Answers
  • Posted on Feb 13, 2009
SOURCE: Garage door opener doesnt close the garage
If you have to hold down the button to close the door, you are bypassing the sensors ...
Check the alignment of the sensors. Should see a solid GREEN light
Anonymous
  • 3197 Answers
  • Posted on Apr 30, 2009
SOURCE: My garage door opener won't close the garage door.
Most likely your door sensors have been bumped and are not aligned properly. Make sure they are pointed at one another and the small light on each one is lit and not blinking.
xenophanes
  • 42 Answers
  • Posted on May 09, 2009
SOURCE: garage door won't close by remote in cold weather
There are ususally two adjustments on garage door openers...
One is for the pressure and the other is for the travel. Assuming that the travel adjustment is properly adjusted...
On a cold day things are a little tighter and it "wants" a little more downwards pressure to complete its cycle. Sorta like me in the morning -- I need a little coffee to get going on a cold morning.
Adjust the down pressure/force just enough to make the unit close properly. Do not over adjust the down pressure or you will find it won't stay closed. Sometimes the manufacturer doesn't make it too clear where this adjustment is, but you should be able to find it if you look around.
I have seen units that were installed for years all of a sudden need a little tweak of this adjustment.
Good luck
Anonymous
  • 143 Answers
  • Posted on Oct 11, 2010
SOURCE: Chamberlain hd900d garage door opener
You will have to open the unit and look inside it. Unplug it first. It should have 6-8 screws to take off. You will see 3 white plastic adjustment screws. There is a carriage they sit in. Make sure they are in this carriage. If you would like stay back a bit and plug it in and watch it run to see how it works. It is a direct contact system, so when the middle screw touches the copper limit of the limit screw it stops. Thanks BB
Anonymous
  • 11 Answers
  • Posted on Jul 29, 2011
SOURCE: My garage door opens fine, just wont close with
Clean both safety sensors lens located at the bottom of the garage door frame. Make sure both sensors led lights are lit. If not they are out of alignment and you will have to loosen the wing nut on the sensor that is lit and move it, trying to get the other sensor to light.
My door still won't close after manual release
Some garage openers have a string/lever next to the main box that needs to be set in it's up-position in order to use the remote. Please check that this is the case for your garage-door opener and trying using the remote afterwards. Otherwise, we might have to factory reset the remote before reprogramming it.
Thank you.
I have bought a new remote how do u get it to work on my eazylift mk door
generally you push the program button/learning button on the motor/head and then push the button on the remote to program. then push remote button one more time to make sure it worked.
2answers
Garage door opener remote does'nt work when the garage door is shut
Probably you have a weak battery in your remote transmitter. When the garage door is closed it requires a stronger signal. Open the remote and replace the battery.
Chamberlain 9902 won't close at times
Does the motor run? Does it make a noise. What actually happens?
1helpful
2answers
Garage door will not close from remote or car. Garage door will open from remote or car; however, it will not close using these controls. The only way I can close the garage door is to press on the manual...
Try reprograming the opener to each remote, if this doesn't work then the command/radio module in the opener is damaged and needs to be replaced. Hopefully you can find one or you will have to replace the whole garage door opener. Good luck.
Bought a universal remote for craftsman/sears garage door, now our neighbors can open our garage with there universal remotes..help how do we stop this
I would go ahead and change the password on the remote and then I would REPROGRAM the remote with the garage door mechanism. It is supposed to have a rolling code. Perhaps your neighbor,s password is coincidentally the same as yours. Stranger things have happened. Below is a link to your instruction manual on-line.
Hope this helps,
Best Regards,
Mark
http://lib.store.yahoo.net/lib/aaaremotes/976LM-manual.pdf
Garage door close but motor keeps running
The close setting limit switch needs adjusted. Once it is adjusted it should work just fine.
Remote
check for brackets that are not screwed in or causing friction
good luck
please mark the post with a fixya
Top Building Materials Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Building Material Expert? Answer questions, earn points and help others
