You can get a standard RF (cable) male connector to AV (the yellow,white and red colored) adapter at radio shack for a few bucks...if it is a internal connection, that will bypass it...you will just be watching cable on AV-1 or wherever you plug it in
Testimonial: "thanks! will give that a try and let you know."
Check the AV section means where the tuner is connected in a circuit. There may be the earthing of tuner is in loose connection or dry solder. So solder it properly
