My Hp fax goes off periodicall when a call comes in. Why?
This does not happen all the time, but it seems to be happening more often. Someone will call in and the fax machine will start to beep away.
It means that your fax machine is "answering" the incoming call before you pick up the handset. Usually, the factory setting on the fax machine picks up after two incoming rings. There are three ways you can address this issue: 1.) You can either change the number of rings to, say, five incoming rings to give you enough time to answer the phone before the fax machine picks up, or 2,) you can find out if your fax machine has a feature that allows for the voice hook "click over" that will allow you to override the fax when you pick up your handset, or 3.) turn your fax machine off until you need to send a fax.
If you want to investigate number 2.), then you'll need your operator's manual.
Good luck.
No, what it does is make that connecting sound like it wants to sent out a fax. So the person on the other end is unable to speak and hangs up.
Do you mean that your fax rings when a call comes in? You also said it starts to "beep away". Do you mean it "rings"?
