Onkyo TX-SR501 Receiver Logo
Posted on Dec 05, 2007
Optical sound I have an onkyo SR501, and it was working fine forover 2 years, but now I can not get any sound from optical port # 1. Optical port # 2 is working fine. How can I repair this problem?
  • Anonymous Jan 21, 2009
    I am having the exact same issue. It was fine one day and then stopped the next. I have tested the cables they are fine...its like the port/jack is simply not working. I thought perhaps dust or fibers had gotten in there so i blew it out with some canned air and that didnt help. I am thinking of opening up the box but am not sure what to look for.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 22, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
492
Points
I think what I might do is use an optical splitter: http://www.amazon.com/Digital-Bi-Directional-Optical-Toslink-Splitter/dp/B0002MQGR2, does anyone have any experience with this?
Best converter for HDMI (ARC) port on TV to onkyo tx-ds555 receiver
Your receiver appears to have a digital optical input, so no converter would be needed, just an optical fiber cable (TOSLINK) between the two optical ports. However, the manual for your receiver states that several functions don't work unless there is also an analog connection. If you must have those, you can use an HDMI audio extractor. You may also need an adapter cable to convert 3.5 mm stereo audio to a pair of RCA phono plugs to make the analog connection.
Onkyo manual page:
https://www.manualslib.com/manual/302250/Onkyo-Tx-Ds555.html?page=8#manual
HDMI audio extractor reviews:
https://headphonesproreview.com/best-hdmi-audio-extractor/
4helpful
3answers
How to connect av receiver to dvd player and hdtv
You can go to the manual at the link below and follow the directions
Links
I want to hook up my onkyo model tx-sr501. How do I do this?
Hello Brenda
Where do you want to hook your ONKYO and with what you want to connect it to.
There are several steps and a lot of devices can be connected to the Onkyo.
1 Speakers are to be connected on the rear side of the device. as it shows in and on the Instruction manual If you have it.
And for other devices each device has its way of connectors.
Optical to optical and RCA to RCA ...
IT depends on What kind of devices you have.
2answers
I'm trying to connect my old onkyo tx-sr502 receiver to my panasonic smart tv and my xbox 360 to get surround sound. Any help would be appreciated
Hello, Since the TX-SR502 does not have HDMI inputs you need to connect the HDMI from the XBox 360 to the TV. You can connect an optical cable from the XBox to the receiver if the XBox has an optical output. If not you can connect the optical out from the TV to the receiver. Connect to the optical #2 port on the receiver and press the video 2 button. You should have audio. Thank you, Onkyo USA
1helpful
No signal is received in the optical input of a 2000 ONKYO TXD 575 Receiver. Remote controller replacement for this unit too the model of the remote is RC-392M
Hi Ben please check the assignment of that port. The port could be bad. I checked several sites for a replacement remote and they are not available. Thank you Onkyo USA
I have an Onkyo TX-SR501 reciever/home theater amp. The sound works fine in home theater mode, but no sound when FM mode selected, but fine in AM mode. Have checked Antenna.
Hi Anil, please make sure the the receiver is locked into the station. It should read FM Stereo when locked in. Thank you, Onkyo USA
Onkyo TX-DS676 Receiver
check that you have selected that option on both player and receiver.
optical setting. a lot of systems are defaulted to hdmi
I try to connect a satelite to optical audio input for a digital radio signal. This doesn't work. Is it only possible to use a coax input cable for the radio signal?
The nature of whatever is on the upstream side of a digital signal is invisible to the device at the other end of the cable. Bits is bits, as we say. The undefined 'satelite to optical audio' device is probably at fault or not set right. PLUS, on theOnkyo you have to assign digital inputs. Read the manuals.
2answers
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Onkyo receiver TX-DS696
If you get sound on direct mode say from dvd but no sound when you go to dolby make sure you have the right input selected by pressing the digitat input button on the front of the amp,ie if dvd optical out is pluged into amp optical input 1 select this on amp then set audio to prologic2.DVDs through this input will decode to dolby digital/dts.
hope this helps.
CABLE GUY.
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
