Digital Mind Corporation iQ Sound SC-PMP2225 MP3 Player Logo
Posted on Aug 28, 2009
The touch screen of my mp4 wont work. I think I changed something on the Calibration settings, but now I can't even get back into that option as the touchscreen is not working now. :(
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
484
Points
Do you get your problem solved i have the same problem i just got mine in the mail today and i have a feeling i have been hosed and it is a xmas gift to my son too??
Anonymous
Level 1:
New Friend:
  • Posted on Dec 10, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
484
Points
I have the same problem... but i didnt touch and settings... i
Bizhub 500. made a mistake during touch screen calibration. Is there any option to enter the screen calibration without touching the touch screen?
Select the Accessibility button ?
Option (1) Touch Panel Adjustment - Touch the four "+" buttons ? Press Start ? Close
My touch screen is not working properly?
Go into "settings", then "touch screen" options and recalibrate.
If the calibration is too far off, you may be able to "walk" it back by touching a point between the crosshairs and where you estimate the phone *thinks* you're touching.
Repeat several times and eventually you should be able to press directly on the crosshairs. You may want to consider using a thin (yet blunt) stylus to press perform the screen calibration for the last time to be sure you're right on the mark.
DCS T70 LCD does work properly .I mean to say if i try to use one function another function gets started instead of desired function
Based on the information you've provided, it seems that the touch screen panel is not aligned. You can try Calibrating the touch screen to resolve the issue.
Calibration option is in the Main Settings 1 Menu of the Camera. Calibration option enables you to perform calibration when the touch panel buttons do not react at the appropriate points where you touch. You can use the paint pen, touch the X mark displayed on the screen. The X mark moves on the screen. Once the calibration option is finished successfully, the touch screen should work.
The Calibration option can be done only if the Menu is accessible.
You can also perform a power reset before performing the Calibration.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
This should resolve the issue.
Thanks for using Fixya.
4helpful
Sony DCR-HC18e Touch screen stopped
The problem you have on your Handycam is the flex cable FP-835.
You have to open the camera and change the cable.
It´s very easy to change.
1helpful
I just got a rockchip 2.8" 4gb touch screen mp4 player. The calibration on the screen is messed up. *what i touch isnt what comes up*. I need to find out how to manually reset the whole system back to...
all yo have to do is take a niddle or something skinny and push it in the side hold the hold is hard to see but it will master reset
Jan 04, 2009 • GPS
MP4 touch screen not working
my mp4 touch screen freezed and turned off. Now it wont turn on. please help
2helpful
8answers
Touch Screen not working
ı have problems about wıth my touch screen. ıt does not works sometımes.
ı have to restart my phone to make ıt work . can ı do somethıng more?
2helpful
Touch screen
The touch screen wont register if the unit has been reset and sometimes when it updates. Use the side buttons to control the cursor. Click the menu button, and then use the down arrow key to slect settings.click settings with the ok button. use the down arrow button to scroll down to display. click ok. The display screen will come up. Use the down arrow key to go to touch screen calibration. Use the ok button to select this option and follow the instructions. You will have to use the stylus to tap three calibration points on the touch screen and it should work fine from there.
Top Digital Mind Corporation Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Digital Mind Corporation Audio Player and Recorder Expert? Answer questions, earn points and help others
