Question about Whirlpool Washing Machines
Whirlpool cabrio top load washer doesn't have hot water solenoid, its missing. The hot and cold valves are fine. Cold water works great, hot water non existent! We opened the control panel and that's when we saw the problem of the missing solenoid (coil). Is it possible to buy only the missing solenoid, it's a invensys 120v 50/60hz 5w.
SOURCE:
SOURCE: Cold water valve will not actuate on Roper top-load clothes washer
the water temperature is to hot
Posted on Oct 20, 2007
  • 1314 Answers
SOURCE: Whirlpool ghw9100lw2 front load washer doesn't use both hot and cold
first make sure the hoses aren't reversed hot on cold or cold on hot next turn off cold water remove the hose from the washer and check to see if the screen on the washer is clogged if not get a bucket turn on cold water and see how strong the water is then let me know what you find dont rate me till we are done
Posted on Jan 10, 2008
SOURCE: HITACHI WASHER SF 6500PX, COLD
hitachi washer sf 6500px lid for washer
Posted on Mar 07, 2008
faggly
  • 74 Answers
SOURCE: Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Posted on Mar 19, 2008
onthejob5130
  • 640 Answers
SOURCE: water temperature control not working
the fill hoses are backwards,,,reverse fill hoses...on the job...also your under warranty ..call for service but you can do it your self..
Posted on Jan 17, 2009
Can't get hot water in my Whirlpool Cabrio washer. Getting a humming sound when selecting only hot water, but no water. Cold water works just fine.
hot water solenoid control not opening
hot water not coming out of wall tap ( tap washer faulty and blocking off flow )
Sep 20, 2018 | Whirlpool Washing Machines
Why is my cabrio washer not filling with water?
If there is no hot or cold water then the control board has a fault, if only not letting in cold then it will be the inlet solenoid that needs replacing and the same if only the hot.
Jun 26, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio Platinum water is coming back out of the hot hose
You have a hot , cold and a mix valve ,I would suspect that the mix valve is stuck, try tapping on it
Whirlpool W10372095 Valve AppliancePartsPros com
May 26, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Water continues to fill into the washer drum on the spin cycle.
Hi
You could have a stuck solenoid valve
Try this: Set the water temp on cold. Turn on only the hot water.
Does hot water try and fill the drum?
If so then there is a problem with the hot solenoid.
Next set the water on hot. Turn on only the cold water. Does cold water try and fill the drum ?
If so then there is a problem with the cold solenoid.
Jan 05, 2011 | Whirlpool LTE6234D Top Load Stacked...
My washer does not fill with cold waer only. Hot works fine
One of two things #1 Check for a clogged screen on the cold water inlet,shut off cold water supply remove the hose at the washer. On the washer side their should be a screen carefully pry it out and clean.#2 The mix valve solenoid for the cold water is bad .thats the valve that the hoses hook up to on the washer .
Sep 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When control on warm or hot no warm or hot water comes out, just cold
The problem is a bad hot water solenoid on the water inlet valve (also known as a mixing valve). There is a separate solenoid for hot and cold water. If the hot water solenoid fails, you will not have any warm or hot water. Replacement is simple and inexpensive. The following link explains how to access and replace the inlet valve on a Kenmore top loading washer:
http://www.fixya.com/support/r3575881-replacing_water_inlet_valve_on_whirlpool
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites offer great service. Prices vary between them so shop and compare.
If you have any questions about this repair, or have need additional assistance, please post back with your complete model number (located along the wash tub rim under the washer lid). I hope this helps you.
NOTE: Kenmore is manufactured by Whirlpool, so these instructions do apply.
Dec 10, 2009 | Kenmore 22422 Top Load Washer
Washer goes through wash cycle fine but when time for water to run into washer for rinse cycle, no water comes in.
Check for a cold water supply problem, since cold water is what is used in the rinse. Check the water inlet valve. Remove the water supply hoses and check the small metal screens inside the openings on the valve. Make sure they are clear of rust or debris (especially the cold water side) and check the solenoids. They can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid. I will attach a photo for reference. Hope this helped and best wishes.
Sep 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
LTE6234DO Whirlpool Thin Twin-No hot water
The inlet valve that the hoses attach too the solenoid for the hot side may be stuck closed or clogged with sediment. May need new inlet valve.
Mar 18, 2009 | Whirlpool LTE6234D Top Load Stacked...
Washing Machines Logo
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
