My iphone is stuck on the apple screen i just updated an app is this anything to do with it and do i need to reboot my fone help :)
If iPhone won't turn on, or the display freezes or doesn't respond
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Testimonial: "the last option helped alot thanks x"
One Click Exit iPhone iPad Recovery Mode:http://www.datas-recovery.com/static/out... iPhone Data Recovery or iPhone Data Recovery(Mac) is an all-in-one solution that helping you to fix iPhone stuck in recovery mode or Apple logo screen, and recover your lost data with the professional application, even after update to iOS 7 or jailbreak iPhone on iOS 7. The program is 100% reliable and complete applys to iPhone 5S/5C/5/4S/4/3GS, iPad Air, iPad mini, the new iPad and more. Step 1: Fix the Problem with iPhone Data Recovery Step 2: Recover Data from your iPhone Directly Step 3: Recover Lost Data from iTunes Backup I hope that will give a help.
Try this to fix the issue that iPhone stuck on Apple logo:
Hold both the home and power buttons at the same time. When the Apple boot logo appears, let go of the power button but continue holding the home button.
I will help you to solve your problem, don't worry just
follow as I say.
1. Firstly it is not a big problem just do as I say.
2. Connect your device to the PC and then launch the
iTunes software.
3. And then go for the option of 'Restore' in that iTunes.
But if your device doesn't respond to it .
4. Then try to update the iTunes software to latest version.
And using windows OS means you need to uninstall the
whole previous version of software and need to download
and install the latest version of it.
5. And if you are having the third party apps such as
Antivirus and etc are installed then it will object your phone
to respond to iTunes. So you need to update your iOS
software at any cost, which is the only way to fix iPhone stuck at Apple logo.
All the best
Read more: http://www.recovery-ipad.com
Swrh se ay aer sryhER S AERY AERY AEYR
